Clutch slipping?
Re: Clutch slipping?
Postby petroscf » Mon Sep 04, 2017 9:59 am
hehe thanks!
Now off we go to solve the next 2 issues:
1) to check on the diff noise and final decision of diff ratio -Guess will give a try to a rack and pinion from 3.45 to see 2 things: a) if noise stops and b) if I like it a bit longer
And also to 2) solve the oil fumes issue - fumes way less now, but still there and smelly, and I guess I am going to air filter box way in order to turn them in?? if this might give us the solution
11.09.2017 - Now I saw I should be writing Crown not Rack :-)
/oo=00=oo\
E21 Forever
petroscf
My E21(s): '77 EU 316 (2.0 - manual/dogleg - lsd)
Postby petroscf » Mon Sep 04, 2017 12:25 pm
Oh, and also a 3rd one: the weird issue of water temp rising up whenever I drive uphill
(Yes I know all the above are off topic, but they're still the remaining issues to find solutions after my clutch slipping issue which seems now to be resolved)
/oo=00=oo\
E21 Forever
petroscf
Postby petroscf » Mon Sep 11, 2017 9:49 am
gerrit323 wrote:Are you sure a 6 cil fly wheel will work ok on a 4 cil car.
Whats the weight of your current fly wheel .. i think 323i is 6.4kg
A question here: What are the pros and the cons of a lighter or a heavier flywheel?
I mean, the mechanic fitted one from 323i but lightened. However, it is heavier than the other one I had (and -I think- I can feel my acceleration affected abit-or this might be just my idea?)
/oo=00=oo\
E21 Forever
petroscf
Postby petroscf » Mon Sep 11, 2017 11:25 am
https://www.racetep.com/engine-building ... ening.html
these guys here give a bit more heavy figures for 2002 flywheels- I guess they are the same for M10s?
/oo=00=oo\
E21 Forever
petroscf
Postby petroscf » Thu Sep 14, 2017 12:08 pm
Anyone any opinion on heavier/lighter flywheels-and if lightened, how much?
/oo=00=oo\
E21 Forever
petroscf
Postby gerrit323 » Thu Sep 14, 2017 2:09 pm
Lightened flywheels do give you better acceleration but once at speed the engine has to work harder to keep that same speed because of the lower inertia the flywheel provides.
If your engine has not alot of hp and your flywheel is to light your uphill speed will be affected .. the engine will have problem to keep its revs up when going uphill.
e30 318i 1987
e30 320is 1988
e36 m3 1994
Abarth Tourismo 2016 165hp
Fiat scudo 2016 workhorse 199hp
Postby petroscf » Thu Sep 14, 2017 3:01 pm
With the former flywheel I did not have issues on uphill chases :-D
In general you are for or against a bit lightened flywheel and how much?
/oo=00=oo\
E21 Forever
petroscf
Postby petroscf » Thu Sep 14, 2017 3:08 pm
Oh maybe the answer I am looking for is here: After replacing for a different flywheel, should, in general, webers be again set up??
/oo=00=oo\
E21 Forever
petroscf
Postby petroscf » Sat Sep 16, 2017 9:06 am
because of heavier crakcshaft maybe?
/oo=00=oo\
E21 Forever
petroscf
Previous
Return to E21 Technical
Who is online
Users browsing this forum: No registered users and 20 guests
