VDO Gauges
cdavie2002
VDO Gauges
Post by cdavie2002 »
Got this, just need to know what senders, and other bits and pieces i need, and how to connect them all up?
In bottom picture, left to right is Volt meter, oil pressure, oil temperature.
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
Red = live
Black = earth
The 3rd termonals are for the sender units to connect to.
The lights are best connected to cigarette lighter bulb and will also then work with the dimmer switch.
cdavie2002
Thanks
How do i hook up the live wire, is it supposed to have its own individual connection in the fusebox?
Chris
1975 3.0 csi
2003 E46
Any live will be fine - they don't draw much current.
Jason_323i
Post by Jason_323i »
You also need the VDO specifi senders
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
cdavie2002
Is this the right oil pressure sender?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Chris
1975 3.0 csi
2003 E46
--ALPINA--
Post by --ALPINA-- »
No good!! your bar pressure is 0-5 the one on ebay is 0-10 you wont get the correct reading ive tried a 0-10 and didnt give the correct reading, i orderd all my sensors from the US.
J
cdavie2002
Who from in the US?
Chris
1975 3.0 csi
2003 E46
--ALPINA--
VDO usa, dont bother trying europe VDO, they are useless, the market in us for vdo`s re greater even thou its all german. i had to order a 52mm VDO vacuum guage for my Throttlebodies and a stewart warner rev/shift light in 52mm, here in europe you`l probably find a a cow with two heads before you source namely!
J
cdavie2002
Ok, vdo US for
-5 bar pressure sender
-adaptor to make it fit our cars(thread sizes?)
-sump plug oil temp sender
Yeah?
Chris
1975 3.0 csi
2003 E46
--ALPINA--
cdavie2002 wrote:Ok, vdo US for
Yeah?
Vist this site http://www.parkerperformance.com/ I used these guys to get thru to VDO USA cos they only let dealers contacting them for ordering NOT public and VDO USA only helps with part numbers and enquiries..
So the part nuumber you need are as follows:
# 323-092 which is the oil temp sender which is a 17mm hex sump plug type, costs $25.00
# 360-003 is (80 psi) 5 bar oil pressure sender and costs $24.00
Email mike or his wife miranda with those part numbers and a total cost including shipping to the UK, and he accepts Paypal for easy money transfer aswelll!!
Goodluck!
j
cdavie2002
I have emailed parkerperformance about those parts.
The pressure sender seems to have only one contact point on it, missing the one for the dash warning light, is that correct?
Also the dash warning(idiot light), is that just for oil level?
Do i also need an adaptor for pressure sender (like on in pic you posted Alpina)?
Chris
1975 3.0 csi
2003 E46
cdavie2002
Re: VDO Gauges
I have the oil temp sender. And i have the oil pressure sender, i need the adapter for it though.
Chris
1975 3.0 csi
2003 E46
Re: VDO Gauges
I'm following this tread!
I have also a set of gauches like you.
I will order (thanks for the adress) there the senders.
