Hi guys, my dash isn't illuminated! Is it a common problem? Will it be the bulbs? I've checked all the fuses and they seem fine. The main beam and indicators are fine, but nothing else. It makes driving at night a bit weird.
Cheers, Max
Dash lights all out!?
Re: Dash lights all out!?
Did you turn the light switch dimmer? They get stuck sometimes. The bulbs don't all break at the same time so otherwise prolly a wire got disconnected.
Reck
It also took me a while to figure out that the light switch controls the brightness of the dash - have you tried spinning it clockwise?
- Thecatmilton
- Newbee
- My E21(s): '82 US 320i Manual
What type of bulbs fit the dash? I need to replace mine.
- Mihajlo
- My E21(s): 1982 315swap323i
pin bulb 3W
or
pin bulb 5W
or
pin bulb 5W
