M20 exhaust options
Eddie.
My E21(s): [O==[][]==O]
M20 exhaust options
Post by Eddie. »
The M20 is now in and seemingly running quite well.
I was wondering what people do for the exhuast? I've got an idea of what I want, but I'm not sure it's right.
I was going to do:
Both downpipes into a y-connector, into one pipe, through a backbox and then a single exit.
This sound okay?
drjim
Re: M20 exhaust options
Post by drjim »
I have a full 323i system with some stainless backboxes I got off Rob (Wiz0R). Very secondhand. The idea was that it'd look cool, but when I had to weld some steel into the back end to hold it up, and then cut a hole in the rear valence, followed by the MOT man not liking the way it was supported meaning cutting a bigger hole in the valence, I knew it wasn't! SIngle exit at the back is the way forward, for performance purposes it is also lighter.
1982 Saphirblau Baur 325i
Cars all gone!
Eddie.
Post by Eddie. »
Yeah I'm fixed on single exit. Straight cut. I won't be budging on that! haha
drjim
Post by drjim »
Straight cut and shiny chrome is what you need. I keep looking at the Baur and thinking that I need to weld up the hole in the rear valence and get a single outlet. You getting a nice shiny stainless one made? If so I might get one for a group buy!
Track slug has a cobbled together thing so I could do with fixing that as well. So that's 3 cars in the group buy already!
Cars all gone!
mr edd
Post by mr edd »
if you go for a e21 6cylinder 320 system. I have a brand new 320 6cylinder 1977 only back box that i would be happy to swap for your used 4 cylinder back box (if it is good useable condition)....1977 is the only year that a 6 cylinder 320 had the exhaust exit by the number plate like your car rather that at the corner of the valance as later cars....
e21 316 (1981) TRE702X.
Eddie.
Post by Eddie. »
Is that a twin inlet backbox?
mr edd
Post by mr edd »
on a 6cylinder e21 320 the middle box has two inlets and one outlet to the single back box, i imagine a 323i middle box has two in and two outs with two separate back boxes that exit at the corners of the valance... from the middle box back a 320 6 cylinder system looks similar to a 4 cylinder system but has bigger boxes and larger diameter pipework
buhl
My E21(s): excited 320/6
Post by buhl »
Hi, do not use 323i exhaust middle box because of course it come with 2 in and 2 out but after they are very small
look at this : http://www.google.fr/imgres?imgurl=http ... rQMwDTjIAQ
The best way is to do your own exhaust.
