I am getting ready to fit throttle bodies to my M10 and have everything except a crank trigger pulley which has the teeth for the crank position sensor.
I have done some googling and found '02 Again' have one for $229 + shipping from the US, and there is a guy in Norway who will make one for £550!!
Are these the only options other than attaching (welding?) a crank trigger ring to my existing pulley? I am doubtful that this approach will see the trigger ring run true, and this is critical as the sensor has to be very close.
Do the crank pulleys from M40/M42 fit? What about M20?
What is the M10 pulley made from - is it mild steel?
Thanks,
Mark
M10 crank pulley with trigger teeth - best source??
- E21-driver
- My E21(s): BMW E21 315
Re: M10 crank pulley with trigger teeth - best source??
As far as I remember, Ireland Engineering had one for the M10. And no, the others don't fit. And yes, the M10 is made from steel, but not mild.
1982 315 reseda
Thanks,E21-driver wrote:As far as I remember, Ireland Engineering had one for the M10. And no, the others don't fit. And yes, the M10 is made from steel, but not mild.
I couldn't see one on their website so I'll drop them an email.
Do you know what grade the steel is - one option is to weld a stainless gear ring onto the pulley
You can cut it yourself at every shop with a water or laser cutter. I have description posted here:
http://bmwe21.net/forum/viewtopic.php?f ... 15#p289562
