2013 Manx Classic
TopCat
My E21(s): 1980 Alpina B6 2.8
2013 Manx Classic
Post by TopCat »
Well we had fairly high hopes for this year's Manx Classic
usual last minute panic to:
fix exhaust
fix rear height adjustmt
free off front calliper
get it running right
find another Federal 205/50/15 tyre to raise front
fit the E28 engine mounts
In the end the new shiny stainless exhaust would not fit with the e28 engine mounts- so back to the e34 ones- plan was to fit a slightly larger tyre 205 vs 195 to raise front as the worry was that we would ground out on the bumpy Sloc
The tyre didn't arrive in time- and the rear adjust things were the wrong diameter- "top up and motor on"
and we were running well - keeping up with a 7.2 litre Jensen in the same class:
But then on the last dryish run on the Sloc Herman ground to a halt just after crossing the finishing line- I hit the rev limiter on the penultimate corner in third- which was quite a result- but this cooked the ECU
I was convinced it was the silly immobiliser thingie- until we got it recovered back to workshop and tried the old ECU
therefore I did the rest of the event- being the third day at Ramsey- in the Hartge
Lots of thrills and some spills
A GTD40 kitcar managed to spin in its own length at Governors hill taking out the wall and his radiator:
ouch!
other highlights included a real AC Cobra that managed to pip my class record (in Camaro) at Ramsey:
makes me wish I had Butch with me!
All the superfast Caterhams 300+ bhp and 500 kgs - hence called 600Rs were shaded by a spaceship Audi Quattro Pikes peak thing with 850 bhp!
But there again the Audi Monster was itself shaded by the most unbeleiveable PUMA thing- with 650 bhp cossie motor and 4wd- this thing simlpy blitzed the records for unlimited Kitcars
Just goes to show that once you get involved in moderns- there will always be something faster, better with more tech etc than you!
Lesson 1 is to stick to the Classics- and in any event only Classics may win the overall Manx Classic afterall!
Herman was a handful in the damp and bumps and slightly loose surface of the Sloc- quite handy to promote the easy oversteer and slide the back round- like many I simply hate understeer. The really quick rally Escorts were much faster than the Rally Porsches (and Big Red).
Big Red was suitably consistent- when I got into the groove my 3 timed runs at Ramsey were 90.50; 90.46 and finally 90.28
just shows that there really was not much left (pity there wasn't an index of efficiency as we would have won!)
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Re: 2013 Manx Classic
Hoping we'll make it next year. Looks like a great event.
Thanks for the report mate, sounds like you had great fun. Hope you can find a replacement ECU soon.
TopCat
Post by TopCat »
I should add that the previous record at Ramsey set in Butch was a 77.04!
But the news here is that that GTD40 far from giving up rose like Lazerus to compete again in the last event after some sterling work performed by Steve and the use of my trailer
see below:
although he did take it easy with a fastest time of 93.20
the other GTD40 changed clutch plates in the middle of the day and got nil desporandum as a consquence
Regards
Topcat
Patch 'em up and get back out there, love that!
So you'll be bringing Butch then next year?
TopCat
Post by TopCat »
That is a very good question
I have to balance the various equations!
Whilst the challenge has been laid and i wld like to beat the cobra there is no doubt that butch is hugely unsuitable for the classic in current format and with the best intentions butch has sort of moved on in terms of profile and race type events
And in any event am hoping for more e21s next year
Regards
Topcat
TopCat
Post by TopCat »
Big Red in action at the Gooseneck
Looking forward to E21 Mark and others coming over next year to fill an E21 class!
Have managed to add the final run up Ramsey to You Tube in Hartge! My times were eerily similar 90.50, 90.46, and 90.28 being this run
I will see whether it will let me do the same for the (wet) run at the Sloc in Herman the day before.
Regards
Topcat
TopCat
Post by TopCat »
Herman's second practice at the Sloc just after the hailstorm!
Timed run 1 was very wet and slippery- but Timed 2 was vg until ECU let go on last bend but my machine had no battery left!
Very Bumpy!
Regards
Topcat
Some nice videos mate! :thumbsup
Lemme add this to the E21 videos thread as well...
TopCat
Post by TopCat »
Dear J
Are you able to add these to E21 video area or do you want me to?
Regards
Topcat
Well I added it to the E21 videos page here. To upload it to the Youtube channel I should rip it first but why, it's on YT now, right? Shared it on our Facebook page as well so all 'n all you should have some views already
TopCat
Post by TopCat »
thanks
yes lots of hits already!
Regards
Topcat
