Page 4 of 4
Re: BMW-POWER'S 78' E21 320/6
Posted: Fri Mar 11, 2011 8:04 am
by BMW-POWER
Posted: Fri Mar 11, 2011 1:11 pm
by Peter V.
For that construction you need to seperate the handbrake and normal brakesystem then?
Posted: Wed Mar 30, 2011 8:33 pm
by BMW-POWER
i think that everything has to do with cable handbrake has to be removed, and the hydraulic handbrake works on the same circuit with the brake caliper
except the two front wishbones, i have all the parts for a complete 323i suspension swap
this evening went for a 323i torsion axle
front strut legs are being sandblasted, brake calipers are also ready to be mounted with new gaskets and rubbers
Posted: Tue May 17, 2011 9:28 pm
by BMW-POWER
time for another update, front struts are ready, only have to fit the brake jaws + the billies and the H&R springs and we can mount that stuff
Posted: Sun May 22, 2011 8:52 pm
by BMW-POWER
today had some time to fit the billies and the wheel bearings
crappy job to fit the shocks in the struts
nnew bearings, fresh grease and new gasket rings
coming week mount the brake jaws and h&r springs, then finding some time to fit the parts on the shark
still looking for brake disks and pads, anyone proposes for good combinations?
Posted: Sun Jun 05, 2011 10:53 pm
by BMW-POWER
this afternoon finally fitted the 323 bilstein front legs,
forgot to take pics from the works...
brakes are still 320/6, havent got the 323i calipers together.
made a test drive, the car drives very much better, more steady to the road, though much more nervous steering and corner behave,
lowering isnt good viewable, probably because of the little wheels
now mounted is the well known new Bilstein B6 sport shock set in combination with the -35mm H&R new spring set
Posted: Sun Aug 21, 2011 10:56 am
by BMW-POWER
Posted: Sun Aug 21, 2011 11:30 am
by Peter V.
Looks nice! If you would place some new chrome trims at your windows at the front and back it would make it even better.
Posted: Sun Aug 21, 2011 12:02 pm
by BMW-POWER
Peter V. wrote:Looks nice! If you would place some new chrome trims at your windows at the front and back it would make it even better.
i know, soon i'll order some parts for my 2002tii, then i'll order some new chromé strips for this car
Posted: Sun Sep 04, 2011 12:17 pm
by BMW-POWER
Posted: Sun Sep 04, 2011 5:55 pm
by Peter V.
Congratulations. Nice pictures!!!!
Posted: Sun Sep 04, 2011 8:59 pm
by murran
congratulations dude!
are you allowed to just have a hydraulic handbrake in belguim? in the uk you need a mechanical hand brake to pass an mot. tho you can have a hydraulic system too if you want, but its not tested as part of the mot, aslong as the system is safe and not leaking fluid etc.
useful hydro thread with fitting/bleeding guide, pictures and common questions......
http://www.trampdrift.co.uk/Forum/TD/sh ... =handbrake
Posted: Wed Jul 03, 2013 9:35 pm
by BMW-POWER
