Project 326i
pic
Re: Project 326i
Post by pic »
I've written a long time ago. Things was happened with the car, a guy crashed my back two years ago. So I need to replace the tailpanel, bootlid, taillight, bumper, and needs some bodyjob. This accident brought with it that a large part of the car should be painted again. I made a fast repair job, because we want to go to Croatia. I started the real work at the last year, and now, i'm close to the finish.
Re: Project 326i
Cool, any pics during the work??
1980 BMW 528i
Re: Project 326i
So sorry to hear about the crash, glad you're almost done again!
pic
Re: Project 326i
Post by pic »
uwbuurman: I have a few, not too good picture. First, I made a pretty fast "looks like everything okay" work, to go to a holiday. I drilled the tail panel, then screwed it into a thick oak board inside, I hooked with wire rope and pulled it out with a big gas. :launch The end result was not that bad. :D The left side popped out to its original shape. :D Then plastered the tail panel with a lot of fillers. It is good for a year. On the last autumn I started the work. Need some work on the front windscreen frame, a minor work on the right side floor panel, and here we are.
Jeroen: thanks, I did a lot of work on the car, and its just a short post here. :D
The pics in time order after I pulled out the tail panel. I said, that is a lot of filler. :screwy
It looks fine from a distance....
And after one year...wow it doesn't looks that great, time to work :loll
of course, when I need a tailpanel, I can't find, so using an old one. After some care, I sandblasted the whole panel
hmm looks fine to me
...and with epoxi primered
Thats the big story. Not too much pics, but of course I need to smooth the boot floor and there are still a few things that were much shorter in time to describe than to do it.
Re: Project 326i
Wow, good work on the repairs, also the first quick holiday repair.
1980 BMW 528i
Mihajlo
My E21(s): 1982 315swap323i
Re: Project 326i
Post by Mihajlo »
most of people would leave that repair project for some other day... (never)
I'm glad you repaired it so quick!
what was your fuel consumption on trip to Croatia?
pic
Re: Project 326i
Post by pic »
Thank you guys! The fuel consumption was not too good. The average fuel consumption with family and stuff is 12 litres. But I had some fuel leak from under the fuel pump screw. The normal fuel consumption on highway is cca 9 liter.
