323 parts
Cars & parts
BenP
My E21(s): 81 uk 316
323 parts
Post by BenP » Fri Jan 11, 2019 11:55 am
Hi, does anyone have or know where I can get some axel spacers (think that's what they are called, between the rear wheel bearings inside the trailing arms) for a 323i.
Also looking for a UK supplier for the bearings.
Re: 323 parts
Post by Jeroen » Fri Jan 11, 2019 12:20 pm
Dealer?
Re: 323 parts
Post by uwbuurman » Fri Jan 11, 2019 2:55 pm
Bearings just buy them at SKF, much cheaper than the dealer (6 pounds in stead of 120). Spacers in between the bearings go together with a space ring between the arm and outer bearing. You'll need 13 and 7.
For the bearings:
nr 5 = 30X58X16 mm
nr 6 = 30X62X16 mm
These can be bought from SKF. Note that BMW used open grooved bearings, but now it is OK to used closed ones, just go to a store where they can advice you.
1980 BMW 528i
2015 BMW 320dA High Executive Sportline
BenP
Re: 323 parts
Post by BenP » Sun Jan 13, 2019 12:18 am
Thanks for the info, but I'm struggling to find anywhere that sells the spacers. And when you look online for the bearings the sizes listed for a 323 are wrong as I've found out already by buying some and they are the 4 cylinder sized ones. And I really don't want to pay main dealer prices
Re: 323 parts
Post by uwbuurman » Sun Jan 13, 2019 5:52 pm
Sizes that I gave are correct. Can be bought from SKF at any seller/hardware store/carpart supplier. Spacers need te be bought at BMW.
1980 BMW 528i
shadyracer01
My E21(s): 323i '82 Y x2, 1 in resto, 1 now spares
Re: 323 parts
Post by shadyracer01 » Mon Jan 14, 2019 3:27 am
Wychbearings uk can supply 30 x 62 x16 deep groove ball bearing part no. 6206skf at 6.14 +vat. Couldnt find any listing for 58 mm od type though. Maybe worth giving them a call to get further help, all vehicle parts catalogues ive checked seem to struggle to match sizes stated earlier.
BenP
Re: 323 parts
Post by BenP » Tue Jan 15, 2019 10:22 pm
Yes I couldn't find them either, brought them from Germany in the end. And the spacers a found on eBay fingers crossed they are the correct ones !
Thanks for the help !
shadyracer01
Re: 323 parts
Post by shadyracer01 » Wed Jan 16, 2019 1:33 am
You're welcome. So what did you get, can you post here the part numbers to help other members who might need in future please?
