Here are some pics of my 81 320i. It's a work in progress that I drive to work every day, auto cross on the weekends, and generally try to drive the wheels off of as often as I can.
Very nice I like the strut tower bar were did you get it?what part of PA?
The pics took me a time or two to post. hit [img]Then%20copy%20addres%20from%20photobucket%20and%20hit%20preview%20if%20I%20do%20anything%20else%20it%20doesn't%20work%20right.[/img]
77e21turbo wrote:Very nice I like the strut tower bar were did you get it?what part of PA?
Thanks, I made it. I'm about 30 miles west of Philly where are you in MD?
That's what I did with the pictures, not sure what happened.
77e21turbo wrote: I was thinking about making one what did you use for the ends? got any more pics?
I used 1/8" steel plate for the ends. The bar is a 1" aluminum tube with 1/8 walls. I welded plugs into the ends of the tube and then tapped them for a pair of rod ends.
