e21 project
Tan
My E21(s): 1982 323i
Re: e21 project
Post by Tan » Sun Mar 15, 2015 10:21 pm
just a small update. So being let down in November by the welder and then being let down again after I waited till February my dad somehow managed to find a welder who lives 5 minutes from my house and was able to start working on it straight away. As you guys know once you start peeling away at the surface, you see the true extent of work required...
there was a chrome strip probably them old skool wheel arch trims which was stuck on and fillered over, finding a repair arch wasn't hard
the welder told me that the floor had rotted through to the foot well which he has repaired and I got some new jacking plates on order for him to refit
here we are at a bit of a dead end, the welder says he can make something up to fix it but there will be quite a lot of filler work...im not keen on the idea of lots of filler so I need to find him a replacement...anyone who can point me in the right direction/solution would be very much appreciated
jimbob
Re: e21 project
Post by jimbob » Sun Mar 15, 2015 11:03 pm
Try skoda on here, if you look in the for sale section he has a couple of e21s hes breaking.
Maybe he could chop that part out for you. Hes a fair guy and trustworthy.
I had the same thing with my welding took an age.
E36 328i Daily driver
E36 328i Touring
Re: e21 project
Post by Jeroen » Sun Mar 15, 2015 11:50 pm
Fully agree, a wanted ad and some of our regular users should be able to get you some good used material or be able to point you in the direction of suppliers of new metal in some cases as well. Keep going, good you got a good welder in the end!
Re: e21 project
Post by uwbuurman » Mon Mar 16, 2015 10:17 pm
Lots of rust on there. But just hang in there, you'll get it sorted, I'm sure. I've seen worse been fixed.
1980 BMW 528i
Tan
Re: e21 project
Post by Tan » Wed Jul 20, 2016 11:43 pm
so most of the welding has been done, the lip for the boot seal was just fabricated to suit some adjustments will still need to be made once the seal is ready to go back on.
the engine has been removed for the bay to be re sprayed.
m20b25 engine is on the stand ready to get overhauled.
I will take some more pictures of the welding that has been completed so far.
meanwhile I have been having some fun with this.
Image[/img]
Image[/img]
Re: e21 project
Post by uwbuurman » Thu Jul 21, 2016 9:53 am
Oeh, great 4 series GC!!! I think it is the best looking 3 series one can buy at the moment ;)
1980 BMW 528i
Re: e21 project
Post by Jeroen » Tue Apr 11, 2017 3:48 pm
Wondering if the engine is back in yet! :popcorn
Tan
Re: e21 project
Post by Tan » Tue Jun 13, 2017 7:34 pm
I wish it was, engine is still on a stand, engine bay is still not sprayed, however the engine and gearbox have been cleaned and ready to go back in and the engine bay has been sand blasted and primed. i will post some pictures soon. does anyone know where i can have a new VIN badge made up?
Tan
Re: e21 project
Post by Tan » Tue Jun 13, 2017 10:21 pm
Here's some pictures of the gearbox, engine and engine bay so far.
Image[/url][/img]
Image[/url][/img]
Image[/url][/img]
Re: e21 project
Post by uwbuurman » Wed Jun 14, 2017 11:43 pm
Nice progress!
1980 BMW 528i
Tan
Re: e21 project
Post by Tan » Wed Jun 06, 2018 12:38 am
So it has been a whole year since I last posted anything. I am happy to say the car is finished and back on the road. I really do wish that statement was true. Its been more like 1 step forward and 2 steps back. I look at other peoples builds and think where do they get the time to do the work. And how the f**k do they make it look so easy without making mistakes!
So from the last picture the car has been moved in to the garage which was 1 major step forward as it took 3 years for that to happen.
I don't think Simba has seen the light of day for about 8 years
So after the repair works to the underside and cleaning up the rust spots we thought some fresh underseal on those areas would be enough to make it all look original again. the new underseal was grey and the original was an off white/beige colour.
£11.00 per pack and 8 packs were used
I was happy leaving it as it was as the frustration was starting to get to me and eventually it would all look the same once the road dirt and grime gets on it but I was persuaded to have white stone chip sprayed on top of the underseal to make it look more original in colour. But after a few days of the stone chip being applied it started to bubble and peel off in certain places. Mainly where the zinc oxide primer was used on the bare metal after the rust spots were cleaned up and also I don't think the original underseal was properly cleaned and there was still some waxoyl on there. (2 steps back)
£6.00 per bottle and 6 bottles were used
So what to do? tackle the areas where the underseal is peeling off? how do we know that in a years time other areas will not suffer in the same way. Ok so lets take it back to bare metal and start fresh! I did say on a number of occasions we should get the car acid dipped or completely sand blasted but was talked out of it (if the acid is not completely removed it can react with the paint. If the sand is not completely removed it will accelerate rust and can react with the paint. How are you going to get the car to the sand blaster :blablabla )
So we are doing it the good old fashioned way approved by a 60 year old dad (twisted knot wire brush for angle grinder and nylon finishing discs oh and a chisel for the corners)
in a way I am glad what happened did as i wouldn't want to deal with that after the parts started going back on and we also found some other rust spots under the original underseal. We are working in small sections taking off the underseal and going back to bare metal and then spraying fresh primer on.
To keep me sane I decided to buy back my first car after I passed my driving test 17 years ago. Still going strong.
Re: e21 project
Post by uwbuurman » Wed Jun 06, 2018 6:42 am
Very, very recognizable story. This is just the only way to do it right, but you have to be patient, you have to do things like buy other cars to prevent you from going bazirke....
Been there, done that and did not get the T-shirt...
But you are in the right track, taking all the right steps. Great work! Keep it up and keep those pics comming :mrgreen:
1980 BMW 528i
Re: e21 project
Post by Jeroen » Thu Jun 14, 2018 8:13 pm
+1! Lot of work nut the only right way to do it, well done!
BuschBertl
My E21(s): 323i S-Edition E21, 325i E30, M3 E46
Re: e21 project
Post by BuschBertl » Tue Jun 19, 2018 11:51 am
UUUUUUHHHH - did the work two times !! e_surprised
But now it is done right - very good work
BB-Carworks
BMW E21 323i S-Edition 1982
BMW E30 325i Cabrio 1991
BMW E46 M3 Coupe 2001 ... sold 2019 :goodnight
Tan
Re: e21 project
Post by Tan » Fri Apr 19, 2019 10:19 pm
Thanks guys. Back in the garage this weekend after a busy winter. Hopefully get a small update in.
