E36 vs M20 mounts
M20 exhaust side mount on M50 block
M20 Inlet side mount, there's a inlet manifold brace that bolts on behind the mount, but I ground it down so it would clear
Damn it! I won't be able to use my cheap firm mounts since the M20 mounts are too thick
Where the exhaust side mount will sit
Since my car will not be running aircon and all the gubbins had been removed, it seemed stupid to keep the aircon pulley on the crank which takes valuable radiator space away. Since the pulley would be gone, something needed to be done with bolt length. One option was shorter bolts, another was to use spacers, but I chose to butcher the pulley itself.
Gave it a blast of satin black, looks good I think
Final engine position
