316 - 1977 - petroscf - Greece
Re: 316 - 1977 - petroscf - Greece
the e21 has no pollen filter, but it can be done by putting fabric for kitchen hoods at the inlet of the fan
- petroscf
Nice idea!
Where exactly, can you post a diagram showing the point (fan inlet) ?
/oo=00=oo\
E21 Forever
E21 Forever
unfortunately I can't post photos here, but if you remove the fan's sheet metal cover it's not difficult to find where to put the filter
https://www.realoem.com/bmw/it/showpart ... Id=64_0010
- petroscf
Has anyone done this?
Any issues or things worth posting?
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Some days ago, it so happened I was going on reverse, in a mall parking, and the steering wheel was almost all the way turned to the left (or right, I don't remember, but I guess that doesn't matter)
And I heard a clicking noise from the diff.
I made a search in the web and found -in various forums posts- people saying that this is normal with lsd's (as is mine).
Opinions/objections?
/oo=00=oo\
E21 Forever
E21 Forever
Could be indeed, could also be an exhaust mount.
- petroscf
If it were an exhaust mount, wouldn't I be experiencing same or similar noises at other moments as well? It only happened once and while I was doing the specific move
/oo=00=oo\
E21 Forever
E21 Forever
- Mihajlo
- My E21(s): 1982 315swap323i
back in the days when I drove my e21 with bent rear subframe, everything was fine until hard cornering to the left and car leaning to the right and something in that movement started to scratch against each other... like scraping metal sound. can't remember what it was but I guess it was some stupid thing fixable in 2 minutes...
lsd is a bit louder but I would inspect ball joints. they tend to do clicking sound when are under load...
also, check lsd mushroom bolts if they are all still in place. they also tend to undo if red loctite is not used. blue loctite - crap, red - okay
Scraping or rattling sounds are in many cases the exhaust rubbing the propshaft
- Mihajlo
I'd start looking for scratch marks....
- petroscf
Will check, however I only heard this while reversing with the steering wheel almost locked to the one end (can't remember if it was left or right)
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Maybe also I should mention that the clicking noise was rather rythmic, not random (such as "click click click ...")
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
What is that part for?
And where/how is it fitted?
I happen to have one in my hands. Should I fit it?
https://www.wallothnesch.com/en/vibrati ... 1-car.html
/oo=00=oo\
E21 Forever
E21 Forever
- Mihajlo
