Page 2 of 4
Posted: Sun May 14, 2006 8:16 pm
by gerrit323
Also W=0762 EG 323i build March '82
Posted: Mon Sep 25, 2006 10:17 pm
by Mr Lucky
SAZ's says W=1.220 EG.
323i 5 speed normal box built in 1981.
So how come SAZ's has got a one in front and not a zero? What the hell does that mean?
I must check that 320/6 on my driveway too...
Posted: Sun Jan 07, 2007 9:29 pm
by Mr Lucky
Here is the 320/6 speedometer markings.
W=1.300 EG.
What the hell do all these different numbers mean anyway?
Strange...
Posted: Sun Jan 07, 2007 9:53 pm
Strange indeed! Maybe the 0 has something to do with kms and the 1 with mls?
Posted: Sun Jan 07, 2007 10:23 pm
by dazed
seeing as I am in the car here is mine....
w=1.300 eg
320/6 1981 uk
Posted: Mon Sep 17, 2007 6:41 am
by varden
W-0762 EG, on both cars.
Model 323i
Built 1982, aus new.
5 speed econo boxes.
One has 3.5 final drive and i suspect the other does too.
Posted: Mon Sep 17, 2007 9:30 am
by Marco320is
Gooooood post!
Thank you!
Posted: Tue Sep 18, 2007 9:34 am
by dilmah_323i
my Australian cars;
my old 323i built 1981 with 5 speed eco 220kmph (top speed)
no markings on front but sticker on back says w=0.762
my new 323i built 1980 with 5 speed eco 200kmph (top speed)
is marked as w=0.854 eg
Posted: Tue Sep 18, 2007 10:09 am
Well thanks for your info and great pics... and the first time I see a 0.854 speedo!
Posted: Fri Nov 23, 2007 1:05 am
by quaddawg
Here is an interesting one.
No markings at all, not on the front, and not on the back, OR inside.
This speedo was jerky, and making all sorts of noise, like a bad bearing... the car had sat for a long time, over 4 years, before I got it.
I greased the cable, thinking that was the problem, but it didn't help.
I found this post earlier this week, so when I took it apart to fix the speedo (just needed disassembly and lubrication) I looked for the correction factor.
No factor, anywhere.
I am not sure what this speedo is out of, as it is NOT the stock speedo for this car, this speedo was installed when the car was imported, back in 1985, into the US. The mileage was matched with the old speedo when installed. This was done by a company to "Federalize" the car for US regulations.
The speedo is not the stock one, and it is not a 1982 US spec 320i speedo either... not sure WHAT it is, but it isn't marked.
It's also not correct, according to my GPS, it is about 5 miles an hour off, go 50 and you are really going 45, go 80 and you are going about 74, 100 is about 93.5 (smile)
The odometer is off too, but not as badly, it is .1 mile off, every 7.5 miles, or one mile at 75 miles, in other words, go 75 miles and it is reall y 76 miles.... Strange that the Odometer would be incorrect in the OTHER way. Speedo registers TOO FAST, Odo registers TOO SLOW?
strange...
1982 318i Euro, sold in France, imported in 1985 (built in Sept. 1982)
Posted: Fri Nov 23, 2007 2:17 am
by superj
82 320i with 5 speed and open diff
Posted: Fri Nov 23, 2007 10:42 pm
by ac/dennis
I have the same thing with my speedo, I never know how fast i drive.
Posted: Sat Nov 24, 2007 3:01 pm
by e21bimmer
W = 1,393 EG
1983 316
Posted: Sun Dec 09, 2007 11:20 pm
by 3771489
Muke wrote:0,911 = 4,10-differential (315)
0,911 = 4,11-differential (316-1,6, 318)
0,866 = 3,91-differential (316-1,8, 318i, 320/4, 320i-1,8i)
0,808 = 3,64-differential (320i-2,0, 320/6)
0,762 = 3,45-differential (323i)
..and with Mile scale:
number: range: model: diff:
1,465 0-120 315,316,318,318A 4,10 or 4,11
1,393 0-120 320(A)/4,316(A)1.8,318i(A),320(A)1.8i 3,91
1,300 0-140 320i(A(US)),320(A)/6 3,64
1,220 0-140 323i 3,45
1,360 0-140 320i(1.8i)US 3,91
1,266 0-140 320iA(1.8i(US)) 3,64
Btw 0,854 is from 520/4 or 520A/4
Posted: Mon Jan 14, 2008 1:24 pm
by jagclarke
W - 1393 EG
1983 316 5 speed (eco? ) 3.91 diff ?
