short shift
harleytrike
cobbler2u
- My E21(s): 323i baur
323i special
328 sport
Re: short shift
if im not mistaken i think Z3 . I think i read on this forum its been done
- arshad76
- My E21(s): Considering another E21
Re: short shift
Yep that's the one. You can get all the parts reasonably from the stealers. Around £45 if I remember correctly.cobbler2u wrote:if im not mistaken i think Z3 . I think i read on this forum its been done
2.8 is short, 2.9 shorter. I have one fitted to mine and shortens the gear throw nicely
UK Moderator
harleytrike
Re: short shift
will the z4 one fit or do you think it will be too short
- arshad76
Re: short shift
Not sure to be honest. I think I might have heard it does, but honestly the Z3 is a big improvement from the standard shift. Mind you a lot of it is due to new washers etc that will be probably not have been changed during the lifetime of the car.
UK Moderator
Re: short shift
Ireland Engineering sell a short shift kit for e21 for about $170
Just another option...
- e21-Mark
Re: short shift
Z3 one is the best / cheapest solution. If you search all Jimmy/Alpinas posts he put up a comparison of all the different alternatives.
- Jason_323i
Re: short shift
z3 1.8 complete sifter and bushes about £40 from the dealers
Jason
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- TopCat
- My E21(s): 1980 Alpina B6 2.8
- Facebook page: https://www.facebook.com/timothy.c.boles
Re: short shift
Thought I would share our experience of short shifters etc
Got a Z3 one (new ) from Fritz Bits
en route to Final Manx Test found I could only just get into 2 gear as it was fouling the gear lever surround. Was this because of the special Gertrag gearbox Herman has I don't know?
there was no room to move the surround further back lest it fouled the hbrake, but instead of reverting to standard- all was resolved by turning lever around 180 degrees!
now all 100%
now all 100%
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Topcat
- TopCat
Re: short shift
last point on this I should make (having driven Herman to work this morning as it was dry) is that the shortshift shortens the East-West plane as well as the North-South Plane (if you get my drift) and thus this makes Reverse very close to first - you have to go into second before selecting first- for fear of running into the bus behind!
Very similar to the horrid Jaguar Moss gearbox in the early Jaguars- which was almost designed to confuse first and reverse!
Why oh why do European car makers have first in such an absurd position? Far better is the Japanese position being down and to the right (at 5 o Clock)
Regards
Topcat
Topcat
- TopCat
Re: short shift
Regards
Topcat
Topcat
- e21-Mark
Re: short shift
I have no such issues with MIBs gearchange. In fact, it couldn't be more precise if it tried! The same goes for my e30 box too. I just think it has to be a bit of trial & error when set-up initially but can be done.
Reck
Re: short shift
I've done it twice in two years with the standard shifter, thankfully I've realised my error both times before reversing into the car behind me. Is there anything more embarassing to do at traffic lights?
[edit] PS has anyone got a list of part numbers for this conversion? Also, can anyone confirm if it works on a 4-cyl?
- e21-Mark
Re: short shift
On my Mrs 2002tii we just altered the standard linkage. It was pretty straight forward and no difference to a 4 pot e21.
