For the car of a friend of mine this has led to the engine mounts (which are 'ears' welded to the subframe, not the strongest construction) slowly being torn off the subframe... noticeable through rust at the seams.
So... we decided to go for a used subframe and modify it:
sandblasted subframe
Then.. fitted a Turner Motorsport subframe reinforcement kit:
inner reinforcement plate
inside of the ear welded as well, on top of the original welding seams on the outside
outer reinforcement plate
and zinc covering the whole subframe now
Now it's time to add some primer (if necessary?!) and paint the subframe black again.
Please note that any E30 subframe will suffer from this if the car is equipped with a strong engine an/or used in a thorough
Last but not least... this is my buddy and almost neighbour Folkert who took care of the sandblasting and the welding... what kinda chassis needs that much welding... it's a french car!
Many thanks Folkert!
