Brake fluid
Irish_chris
My E21(s): 81 318, 83 316t
Brake fluid
Post by Irish_chris »
Tried a search but nothing definitive
Am I ok to use dot 4 brake fluid in my 81 316, currently it's full of red brake fluid but that's not the colour in the bottle I bought so will be flushing it
Thanks
Re: Brake fluid
Red brake fluid could be anything, for example redline. But if you're not sure better replace. DOT4 is standard spec, should be ok, at least then you know for sure what's inside.
Irish_chris
Re: Brake fluid
for sure! ill be flushing it out and filling with dot4
thanks again for the advice
TopCat
My E21(s): 1980 Alpina B6 2.8
Re: Brake fluid
Post by TopCat »
Dot 4 will make a big difference on track day/hard use will reduce brake fade a lot
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Irish_chris
Re: Brake fluid
TopCat wrote:Dot 4 will make a big difference on track day/hard use will reduce brake fade a lot
very much doubt it will see a track but good to know!
