Pandemoniums 316 restore
pandemonium001
- My E21(s): E12 535i T (ish)
Re: Pandemoniums 316 restore
even if i have to get them re-build, they where embarrisingly cheap for what they are.
I believe they came from a porsche 996 or 997.
hard part now is finding rear's of equal qaulity to match.
- e21-Mark
I have Escort Cosworth competition rears on MIB. They're very nice and I'm sure I've seen alternatives still available. Just a thought anyway.
- Mihajlo
- My E21(s): 1982 315swap323i
i have the vw golf gti mk1 yellow koni setup on the rear
pandemonium001
I have been looking at vw mk1 and 2 stuff, plus anything else that looks like it may fit.
I hadnt forgot you had fitted them, Just purchased a set of AVO adjustables from a escort cosworth to try for now, they are coming with shorter mains and helper springs. AVO only want £25 +vat to rebuild so will send them off and try them, The rear coilovers are the same for the GTX and GTZ kits.e21-Mark wrote:I have Escort Cosworth competition rears on MIB. They're very nice and I'm sure I've seen alternatives still available. Just a thought anyway.
What is the ride height like on the rear?? i was looking at the Bilstein B14 or B16 from a vw.Mihajlo wrote:i have the vw golf gti mk1 yellow koni setup on the rear
- Mihajlo
This is the ride height if I understod correctly... sorry on my englishpandemonium001 wrote:What is the ride height like on the rear?? i was looking at the Bilstein B14 or B16 from a vw.Mihajlo wrote:i have the vw golf gti mk1 yellow koni setup on the rear
pandemonium001
perfect thanks
- Mihajlo
cheers!
I'm glad I can help!
pandemonium001
Managed to get some more done today,
AVO escort cosworth rear dampers Vs E21 with lower springs
Build up the front subframe to save the bits getting lost and clear some floor space.
Rear subframe nearly complete
On the car for a few checks
amber and toe plates work well
Maximum negative camber
mximum positive camber
Need to get those arches rolled!!
No brake disc is fitted so the wheel will be pushed out a bit more still
this is the ride height i hope to achieve but length fo damper at this point is only 16"
damper length set to 21" the free length of the E21 strut.
- e21-Mark
£25 per strut seems a bargain to rebuild those Avo's. I'm sure you know but, for those that don't, be careful when you roll the rear arches. After a certain point the rear quarters just kink and can ruin the panel. I'm sure with your skills though, you'll be able to get enough clearance. I think Mick @ Pristine managed to achieve 25mm on each side. Excellent to see more progress anyway.
pandemonium001
Mark, how did you mount the escort struts at the top, my avo units are 12mm rods vs the e21 10mm.
I may strip them down cut them down and re machine the ends to suit the e21 top mounts,
what was the issue with these not fitting correctly?
http://www.ebay.co.uk/itm/BMW-E21-REAR- ... 0953968867
I may considder them, the camber part is pointless for camber but what it will do is give me more tyre to strut clearance should i need it.
Although would like the rubber mounts for a road car.
- Jason_323i
They do fixed ones as you have to redrill for the adjustable ones, and they can do a 12mm sleeve nut.
Also when running escort rear dampers on the e30 m3 I had to extend the mount up wards (simple welded u bracket) as there was not enough travel and the shock bottom out with the stock mount height
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
pandemonium001
Like this
Need to get to the scrap yard now. or make some to link in a rear brace as well.
- Jason_323i
Not that extreme there was no need to turret the rears, the damper fitted through the shock mount opening and two bits of angle, the upright portions with a half hex profile and a bolt hole in the centre and a cap welded across the top flats for a bit of strength.
I am sure a man of your calibre can visualise that.
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- Jason_323i
My car is gathering dust, not sure when it will be looked at again as my job here is openended. So unless I get a longer term contract on big money so I can triple my rent and get a villa with a garage not much is going to happen.
At the minute I am tinkering with my caterham in the public car park to keep me occupied.
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
