Mechanical speedo cable 315
boscha
Post by boscha »
Hello guys, i need advice:
I have 1983 315 with 5 speed manual transmission.
Would like to know if speedo cable is the same for 4 speed and 5 sleed gearbox ?
Is there any difference i.e. does cable for 4 speed gearbox fits to 5 speed gearbox?
polov8
Re: Mechanical speedo cable 315
Post by polov8 »
your speedo cable is in 2 parts, the upper part is shared, but according to Real OEM the lower part differs between 4 and 5 speed cars:
http://www.realoem.com/bmw/enUS/showpar ... Id=62_0014
Andy
boscha
Post by boscha »
On my car speedo is in one part, I have seen on real oem that there's difference, but do not know in what is the difference - in lenght maybe?
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
It fits.
Mine is from 4 cyl model on 6cyl :)
and yes, only difference is in length.
boscha
Post by boscha »
Thanks Mihajlo.
You think 4speed cable will fits on my 5speed gearbox inspite it's a little bit shorter?
It is tight but it does fit indeed.
Mihajlo
Post by Mihajlo »
boscha wrote:Thanks Mihajlo.
I have it that way also :)
mcjjordan
My E21(s): Uk 1980 316 m52
Post by mcjjordan »
The 4 speed m10 i have is too short to fit onto m20 5 speed so i guess il need the other cable...
Mihajlo
Post by Mihajlo »
I believe 4cyl cable is too short to fit 6 cyl RHD model
LHD cars don't have that problem.
That may be the difference indeed. No issues with LHD but with RHD you have to move over to the other side of the gearbox!
Mihajlo
Post by Mihajlo »
BINGO!
it must be working on the LHD cars then, not so much on RHD ones. :)
