Great to hear the Bilstein and Eibach setup is recommended here as well. Can't wait to start working on the car. Got to finish installing the exhaust and bumper from 4Wheelonline onto the Jeep this weekend.uwbuurman wrote: Fri Aug 06, 2021 11:09 am 1: bilstein-eibach setup. Not to low, not to hard, but much better than oem.
2: sportgearbox. So much fun driving in the mountains
3: pop out windows rear side. Combined with the sunroof they'll cool the car, even in hot summer conditions
4: e30 rear brake upgrade. Much better balance in the car when braking harder and more often. (See #2)
5: a blonde babe, such as my daughter. So much fun driving around with that female mini-me. Building memories.
Your top 5 performance mods?
Re: Your top 5 performance mods?
- petroscf
Very happy with this set up as well. And, although everyone was proposing B6s claiming that the car would become too stiff with the B8s, I chose to hear Bilstein official prompts who said that B8 and B6 have the exactly same rate, only B8 are specially made for lowered springs, while B6 are for factory height springs. Bilstein suggest definitely B8 if combined with springs with lower than factory height.LloydRT wrote: Fri Oct 01, 2021 5:14 amGreat to hear the Bilstein and Eibach setup is recommended here as well. Can't wait to start working on the car. Got to finish installing the exhaust and bumper from 4Wheelonline onto the Jeep this weekend.uwbuurman wrote: Fri Aug 06, 2021 11:09 am 1: bilstein-eibach setup. Not to low, not to hard, but much better than oem.
I am so happy I made this decision. Car DOES NOT FEEL any stiffer than my previous combination (APEX and B6)
/oo=00=oo\
E21 Forever
E21 Forever
Hey everyone, I've been a member of Jeroen's group on FB for some time, but it's upgrade time.
As someone who's been modifying and restoring his E21 in bulk, I have been guided by the information found here, so I have very little in terms of personal impressions on what works and what doesn't.
My E21 is originally 316, but the times of the good old M10B16 are long gone. In its place is the not-so-coveted option of the M30B30 with Getrag 260 out of E32, 3.45 LSD with added tensioning (purported 40% lockup).
I have already acquired the front and rear strut brace, along with the "Alpina" low brace, the entire 323i brake system (with Wilwood proportioning valve for the rear axle), a set of Recaro Orthopaed to help my aching spine and I'm about to do something about the shocks and springs. My choice has fallen on Bilstein B8s for shocks and I am puzzled if I should get H&R's (-35mm on both axles) or MTS Technics (which lower 40mm on both axles but appear to be progressive). I wonder which would work best with the B8s and if there are more (and better) options. The car will be mostly street driven with my choice being mostly on twisty mountain roads.
polov8 wrote: Sun Aug 08, 2021 12:42 pm I can only contribute from my personal experience of owning one E21 and it being a 1.8 M10 engined car, but it is in daily use currently, and any work on the car has been to restore it, improve its performance, or day to day usability.
4, Brakes, I'm still running the stock rear drums for now, they're adjusted properly, and as the MOT test proved, are wrking perfectly, the handbrake is as good as any car I've owned, so they can stay for now. At the front, I upgraded from tired non vented originals, to EBC vented 323 discs and pads, with refurbished calipers with spacers to widen the them for the new discs. Replaced all the flexible hoses with Hel stainless ones, and overall I'm very happy with the brakes right now.
Do you by chance remember where you got the caliper spacers? I have been trying to find some instead of doing wilwood calipers.
Sorry for resurrecting an old thread.
This thread never expires.
- polov8
I made them myself out of a chunk of aluminium. I modified a bolt spinning it in my drill while grinding it with my angle grinder then ground in some flutes to make a milling tool to make a recess for the seal, and then just filed the outside of the block to match the profile of the caliper halves. I think it took a morning, and just required some longer bolts and an extra O-ring. When you split the calipers, one side has the recess for the O-ring, and the other is smooth, so your spacer block has to match this, with one smooth side to meet the O-ring in the caliper half, and one O-ring to meet the smooth caliper half.Morradi wrote: Thu May 15, 2025 6:59 pm
[imghttps://i.imgur.com/GoE7MkO.jpg][/img]
[imghttps://i.imgur.com/77IbHp1.jpg][/img]
Andy
grojaso@gmail.com
- Newbee
- My E21(s): 1982 315 4 speed manual, ugly interior.
grojaso@gmail.com
- Newbee
How are you?
I have a nice 1982 315. Currently with a 38/38 and a 2002 intake, it runs just fine.
I have a lot of parts in stock, H&R springs, KyB struts, 320is bars front and rear, and also blue braces front and rear, and a 320is LSD rear diff.
I do have a M10 1.8i motor waiting for resurrection, and also a 5 speed from an M10 E30, and an E92 M3 left side exhaust header.
I bought a Fury X Linkecu computer, and a Audi throttle body, pedal and 48V motor/alternator.
I'm writing to you, because I haven't read of anyone who has modded a E21 into a mild hybrid, as I want to. Being a geek, I have ran a lot of simulations, and it should be fine. It'll be great to hear from you about this.
I'm attaching some of the numbers I'm working with;
Comparative Analysis & Optimization of M10B16 vs. M10B18 with EFI and ISG Integration
1. Engine Performance Comparison
Parameter M10B16 M10B18 Difference
Displacement 1.6L (96.4 ci) 1.8L (107.8 ci) +11.4 ci (+11.8%)
Compression Ratio 9.5:1 10.0:1 +0.5 CR
Peak Power 168 HP @ 6,000 RPM 193 HP @ 6,500 RPM +25 HP (+14.9%)
Peak Torque 155 ft-lb @ 5,000 RPM 174 ft-lb @ 5,000 RPM +19 ft-lb (+12.3%)
Volumetric Efficiency 103.9% @ 5,000 RPM 105.4% @ 5,500 RPM +1.5%
2. EFI & ISG Integration Strategy
Ignition Timing Adjustments
RPM M10B16 Timing M10B18 Timing Optimization Goal
1,000 27.2° 28.3° Reduce for low-RPM knock
5,000 40.4° 41.7° Fine-tune for peak torque
7,000 41.8° 43.0° Prevent valvetrain stress
ISG Torque Assist
RPM M10B16 + ISG M10B18 + ISG Total Torque Gain
1,000 63 + 75 93 + 75 138 → 168 ft-lb (+21.7%)
5,000 155 + 30 174 + 30 185 → 204 ft-lb (+10.3%)
7,000 127 + 15 143 + 15 142 → 158 ft-lb (+11.3%)
ISG Torque Assist
Cheers!
GRO.
GRO.
lavoro interessante, seguo....
- transfer76
- Newbee
- My E21(s): 79 EU 316 manual
Hi guys! I am so grateful to have joined your community! I only have one mod to improve performance for next year, which is to finally complete the restoration process and leave the workshop. My estimate date is August 1st
But to be honest, this date has been postponed for the third time
Happy new year to everyone!!! Peace)
Well, good luck to you and hope it goes well. Definition of a mod in this context is something opposite to restoration, it is modification
You are most welcome here, and I really hope that the situation in your country doesn't mess up your plans even more than it must be messing up your lives already! Feel free to open a project topic in the Owner's Gallery.transfer76 wrote: Sun Dec 28, 2025 1:16 pm Hi guys! I am so grateful to have joined your community! I only have one mod to improve performance for next year, which is to finally complete the restoration process and leave the workshop. My estimate date is August 1stBut to be honest, this date has been postponed for the third time
- transfer76
- Newbee
Of course!) I got it) my project is not only restoration)Amur73 wrote: Sun Dec 28, 2025 3:31 pm Well, good luck to you and hope it goes well. Definition of a mod in this context is something opposite to restoration, it is modification![]()
- transfer76
- Newbee
Thanks a lot for your wishes! I appreciate it!Jeroen wrote: Sun Dec 28, 2025 4:16 pmYou are most welcome here, and I really hope that the situation in your country doesn't mess up your plans even more than it must be messing up your lives already! Feel free to open a project topic in the Owner's Gallery.transfer76 wrote: Sun Dec 28, 2025 1:16 pm Hi guys! I am so grateful to have joined your community! I only have one mod to improve performance for next year, which is to finally complete the restoration process and leave the workshop. My estimate date is August 1stBut to be honest, this date has been postponed for the third time
Sure, I have a lot of logs and images) and gonna create project topic in nearest time
thanks)
