I think this guy has bailed out, hasnt been here for a while, to fit the angel eyes, is exactly what you see on that car above is what i have on mine.. fisrt of all it fits but you have to bend here and bend there the light bracket on the front panel, i used a pair of pliers, so it cant be that hard eh?
if / when you get your lights take the complete front grills and lights out and put the lights against the bolt up area and screw down what fits before you start bending the vrackets, then put plastic grill back on to see if it lines up and looks right and from there by your judgement you will know what to bend to keep it looking right, then you may need to drill a small screw hole on one side on the front panel to hold that side down and sorted!!!
it took me 15 mins each side to get as pefect as possible, to be honest i took too long on each side cos i kept stopping and looking at each angle (not nessesary) once youve done both sides, take the lights off and start cutting the wiring and wire the new lights, what i did was i snipped som light connection wiring from an E30 so that it fits straight on to the light cluster so if i decide to take em off i can fit an early period E30 lights (example) BUT once you start bending here and bending there id forget about going back to E21 lights cos its all gonna be out of adjustment and also the wiring..... look forward not back on lights, it does look very nice, i only ever seen my car with lights on in the dark once that same night i fitted them cos i never drive it .. not yet anyway!!!
any probs, pm me or post ill guide you thru..
j
