The Surfers New Board
- Silver Surfer
- E21meister
- Silver Surfer
- E21meister
- --ALPINA--
Wouldnt it be more of a common sence to replace the Cambelt, cambelt tensioner and water pump before the engine went it? its something that is naturally done when doing an engine conversion and re-build!! this way its easier, also a new clutch on the gearbox, saving the hassel that when you drive possiblely 2-3 months down the line the old clutch may be loose ready to rumble.......
Its something ive always done when rebuild or engine conversion have been carried out..
Seems like this saga with the car is running thru till next summer.
do it once and once for all. ie. no f-----g about!!
j
j
Mobster
the other thing though is think, if i replaced the cam belt and for some reason it didnt start, its always one thing that could of gone wrong, better to always get a second hand engine in get it running and then change belt. fair enough if doing a straight engine swap like for like. my thought always is if it aint broke then dont fix it. why spend hundreds fixing sumin that aint broke yet.
- e21-Mark
- E21 Master
I'm wondering why the cambelt tensioner or water pump should suddenly starting making a racket just because you've swapped it over?
Did you drop it accidentally or bang the front against anything?
Did noise start as soon as engine fired up?
The fact that the noise only happens at a specific point in the rev band suggests it's caused by vibration so I'd be more inclined to think that something is loose?
- Silver Surfer
It's almost sounds like a nut is loose or something, but one of those annoying ones where you'll never really know until you take everything apart, at which point we may as well change the belt, tensioner and pump as was originally planned anyway.
Gonna order the water pump today, BMW sell it for £75 plus vat! GSF for about £36, euro carparts have one for £20 (Circoli) and one for £36 (KWP), anyone know the difference between these brands?
- Silver Surfer
Just got off the phone to Ben (Duracel), he has an interesting theory. He reckons it could be the broken gear box clip that could be causing the noise. Makes sense as the engine had no noises or problems before when it was with the e30 gear box, now that the e21 gear box has gone in (with a couple of broken bits) and is bolted to the block it could be the vibration from the broken clip travelling towards the front of the engine somehow..
One way of checking it could to push down the gear lever and then take the engine to about 2-3,000 rpm to see if it still vibrates, if it doesn't we know what it is, if it does, back to plan A. Also, as Ben suggested, just hold the gear stick take it to 2,3,000rpm and see if the vibration can be felt through the stick.
- e21-Mark
- E21 Master
Personally, I'd go along with that although trying to identify a noise without hearing it is like trying to describe the colour blue to a blind man.
It just seems unlikely, not to mention unlucky, should either the tensioner or pump have failed at that exact point in time. Not impossible though I guess?
I bought the £36 GSF pump by the way, and it was fine.
- --ALPINA--
If someones confident to rebuild an engine and to do a swap then im sure its not difficult to change the belt.. its true to say ifit aint broke dont fix it, but when the timing belt breaks then whos fixing that, the whole head will have to come off it if valves get bent .. the timing belt is like women, unpredictable !!!.. tensioner needs to be changed to cos it runs on bearings and if it falls apart then the belt loosens, jumps teeth and SSSSNNNNAAAAPPPP .. also when there on the way out it wines loudly..... ive been thgere seen it all and its something to be avoided unless you all enjoy spending money 1 thing after anither... BUT the cars runs perfectly and job well done.. everyones happy..austin25uk wrote:the other thing though is think, if i replaced the cam belt and for some reason it didnt start, its always one thing that could of gone wrong, better to always get a second hand engine in get it running and then change belt. fair enough if doing a straight engine swap like for like. my thought always is if it aint broke then dont fix it. why spend hundreds fixing sumin that aint broke yet.
Also the rattling noise, take the cam cover off, and look under the cam cover, there is a long plate/shield which is held by rivets, i bet its that that loosen and the rockers are hitting it, thus the faster you got more mettalic sound you will get, i had that last year in my engine.
[/b]
- Silver Surfer
