Rear Discs?
MAG!
Re: Rear Discs?
Post by MAG! »
Hello Dude!
yeah they should be close try turning them to insure they're not touchin anything
then test the calipers for proper fit.
goodluck
1972 BMW2002ti
1973 BMW2002tii
1978 BMW e21 M42 swap
2005 Cadillac STS V8
drjim
Re: Rear Discs?
Post by drjim »
Yep they are pretty close but spinning is done parallel to the backing plate so no grinding noises happen.
1982 Saphirblau Baur 325i
Cars all gone!
cdavie2002
Re: Rear Discs?
Post by cdavie2002 »
Im just wondering if iv missed a part out or something. I know that the disc will sit fairly close to the plate, but right now its just sitting very close. Wont know for sure if it grinds until iv got wheel bolts on it, which i need to buy. Has anyone a library photo of the clearance beteen plate and disc.
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
Jason_323i
Re: Rear Discs?
Post by Jason_323i »
That looks about normal as remember having to dig gravel our of the back plate after running of talent one day and thinking f**K how does it get in the there.
It will not rub with bolts, if you bolts are to long (and i have done this) they will catch the handbrake shoes before hitting the back plate
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Re: Rear Discs?
yes they do. the middle of the back plate is on a few mm from touching...
cdavie2002
Re: Rear Discs?
Thanks, i just wanted a bit of reassurance. Next job is to modify aluminium bracket so the caliper fits in place.
Chris
1975 3.0 csi
2003 E46
Jason_323i
Re: Rear Discs?
Are you usign the wilwoods on the rear, what are you doing to adjust the brake basis to compensate.
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
cdavie2002
Re: Rear Discs?
Not 100% sure, however i think i need some sort of proportioning valve, and a reisidual valve.
Chris
1975 3.0 csi
2003 E46
Jason_323i
Re: Rear Discs?
If you want probably best to give us a ring and talk through the brake therory
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
