keep up the good work!!!
quinn_656's 323
- BMW-POWER
Re: my e21 beginning to emerge from the rust new PHOTOS
very nice job done, a learning topic for myself and many other forum readers i think
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
- quinn_656
Re: Quinn_656's e21 now gloss red and not rust red
finally after three years we are seeing red but in a good way the finish straight from the gun is exceptional for an old garage Greg the painters work has been second to none and his boots are really really red lol he'll be back next week hopefully when i have her roughly panelled up to flatten and polish. here are a few pics bear in mind the old fluorescents dont give a true representation of the colour. check out the overspray while painting
My build
www.quinnpiling.com
www.quinnpiling.com
- Smartie
- My E21(s): 320/6 '78 rip
Nice!
This is really RED.
This is really RED.
- quinn_656
Re: quinn_656's 323i now verona rot not rust rot
its an old 70's red i think in my opinion it suits the chrome well
wheels should be back from the polisher this weekend he sent me a pic cant wait
My build
www.quinnpiling.com
www.quinnpiling.com
coming along nicely will it be ready for the bmw classics ireland run in march 2011
- quinn_656
do you know what in the back of my mind that is coming close to the the time of year i would like to have her built so you never know where is the run what are the details?
My build
www.quinnpiling.com
www.quinnpiling.com
- quinn_656
Re: quinn_656's 323i check out the rimmage
quick update
have to show you guys the rimmage im really happy with them found a top guy who is not hard to pay to polish them and he painted them while he was at it the graphite was a last minute spur of the moment.
i now have the sunroof back in doors and bootlid fitted and gapped the respective wiring, mechanisms and rubbers though im going to concentrate on the suspension and subframe over the next while.
still not flattened and polished need to fit the wings and bonnet yet
forgetting about the quaife idea going to meet a guy up the country tomorrow with a small case e30 diff 3.91 ratio i think i may be able to swap the gubbins over. any thoughts?
My build
www.quinnpiling.com
www.quinnpiling.com
- e21-Mark
- E21 Master
Re: quinn_656's 323 RIMMAGE
Another cracking e21 in the making!
cobbler2u
- My E21(s): 323i baur
323i special
328 sport
Looking good and really red.
- quinn_656
cheers guys just trying my best with what i have
lifted my small case e36 318 is (i think) limited slip diff on saturday evening and built it in to my casing on sunday you need to buff the sides of the casing to let it roll down in it really is so little that a couple of minutes carefully with a 4 inch grinder does it. when its in so long as you change over your crown wheel everything matches up perfect. i really think it will be a good job in the car.
took the back axle and front cradle into work and one of the guys shot blasted it for me while he was blasting somethin else so it will be off to the powder coaters later in the week.
my 323i front shock inserts are buggered does anybody know where i could get a good set of bilstein or koni inserts (good second hand would be ideal) just realised that they were a little fatter than my 320 ones.
My build
www.quinnpiling.com
www.quinnpiling.com
- arshad76
Lovely job quinn, nice and thorough. I like your graphite centres, might nick the thought on the MSW's I want to have refurbished
UK Moderator
- quinn_656
i think i nicked the idea from someone else any way so i dont think they'll lock you up lol
My build
www.quinnpiling.com
www.quinnpiling.com
- e21-Mark
- E21 Master
Don't spose you took picks of the LSD case swap?
- quinn_656
i took the camera out before i started went to turn it on and someone had swiped the batteries although im going to change the crown wheel and pinion from the standard 323i (3.45) ratio to something a little lower possibly a 316 set up i think a 3.91 ratio would be ideal (have you any thoughts) so will take a few photos for you then.
My build
www.quinnpiling.com
www.quinnpiling.com
- quinn_656
Re: quinn_656's 323
bit of an update on the motor fellas
have the whole shell waxoiled but still not flattened and polished.
have my diff nearly sorted just waiting on a couple more seals i used the 3.91 crown wheel and pinion from the e36 318is i think im happy with the backlash though im in no way an expert.
all the suspension components back from powdercoating great job
heres my rear axle with new polybushes
i now have some engines to play with just got them yesterday a complete 325i sport engine from an e30 and a 2.7 engine from 525e along with a 316 shell
everything else painted black at the minute im concentrating on brake lines fuel lines and fitting a fuel pump i've also refubed all the calipers
i'll be needing a little advice on the 2.7 setup lads if anyone has any experience of it
My build
www.quinnpiling.com
www.quinnpiling.com
