wiring for 325i conversion in a 320
murran
Re: wiring for 325i conversion in a 320
Post by murran »
drjim wrote:The other thing I discovered was that in an auto there is a start inhibit relay under the dash next to the wash/wipe controller. You need to pull it out and jumper two of the terminals - can't remember which and my car is now reassembled so I'm not able to check easily. 5 minutes with a multimeter some crimps and a bit of wire will get you going.
Jim
me an jim both found this, the inhibitor relay needs bypassing. pull the relay, the two big wires need bridging.
the inhibitor relay intersects the starter wire if its not in "park".
