Hello from Manchester UK
E21 Addict
Re: Hello from Manchester UK
Post by E21 Addict »
mupetmagnet wrote:thats a good looking car mate!
id say just get out there and use it, i drive my 316 4speed to germany and back pretty regularly! enjoy :mrgreen:
I do Man :driving In fact i will get in touch with the people around my area and see what they suggest to start with as I got a lot in mind....Love the fact the tail kicks out easily even with 1.8
Btw: I got a question for you E21 geeks
what do I need to get this set of wheels fitted on my e21 ?
http://www.ebay.co.uk/itm/BMW-E30-3-Ser ... _500wt_949
Jay
20mm spacers I think?
Reck
Post by Reck »
Yeah, my car is wearing those wheels at the moment and is on 20mil spacers.
E21 Addict
Reck wrote:Yeah, my car is wearing those wheels at the moment and is on 20mil spacers.
Thanks Guys.
Reck, do you still remember where you got them from ?
Jay
E21 Addict
Excellent, Always helpful Master Mark !! :thumbsup
With regards to the rear wheels are they open minded to a certain ET or require a hub like the fronts? :banana
Jay :launch
m3gaz
My E21(s): looking
Post by m3gaz »
Welcome,Addict.
You've got a good bunch up there to help you out if you need it.Take advantage of there knowledge and you won'tgo far wrong.
Wow,hark at me bummin' up the northeners :blablabla
Gaz
bartgouda
Post by bartgouda »
Jay :launch
They might fit directly, but I'd give them at least the same spacers as you have on the front. Not only will it look silly if your rear wheels are further inward then the fronts, I can also imagine it would be better handling-wise to keep them a the same offset.
drjim
Post by drjim »
I did a trackday with no spacers on the rear as I had a problem with some broken wheelbolts meaning I didn't have enough to fit all four spacers. No change in handling whatsoever. However it looks a bit funny if your rear wheels are set in compared to the front.
1982 Saphirblau Baur 325i
Cars all gone!
E21 Addict
I get the picture now guys . Thank you
My only concern now, If I consider dropping the car would the rear wheels having any rubbing issues ?
Jason_323i
Post by Jason_323i »
Wider front actually help corning if you work the maths, a lot of french hot hatch run wider front tack from the factory, the main reason fro front spacers is to stop the rim hitting the track rod end at on the front wheel, or else it doe snot it
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
E21 Addict wrote:I get the picture now guys . Thank you
As you bring the rear down, the negative camber increases, so the tyres are more likely to just tuck beneath the arch.
E21 Addict
Hello Again
I did not post proper pictures since I joined which I got with me today......was waiting for the right day ! :whistle
Issue 1: The car is not on the standard Shocks/Springs, it is my daily until I graduate in May (3 months time)
I want to get the lowered classic BMW look but still I don't to scratch the M10's bum on every road so I was thinking 60/40 or 40/40 springs?
Not going for coils really just springs for now unless you don't recommend it
Issue 2: The reason to lower is my front tyres are gone so it is my chance to get some wheels on! I was thinking of either 15" BBS basketweave from E30 or some replica 15" from Ebay
Please enlighten my mind with your Advice experts :read
E30 BBS need spacers. I can do you a set of proper e21 ''basketweave'' 15'' Melbers for £275.
Jacko
Post by Jacko »
Another northern E21 owner, you'll have to pop over and say hello. We'll stick details up when we have a firm date in mind - thinking early March time all being well. Keep some weekends clear in your diary. :)
