Stiff throttle after Weber upgrade
davidvincent
My E21(s): 1982 320/6 Lapis Blau
Re: Stiff throttle after Weber upgrade
Post by davidvincent »
E21noob wrote:From what I can understand I had a similar problem when I installed my DVAG 32/36.
I first put a universal linkage kit on, but it was like you descibe abrubt and sudden. http://www.dellorto.co.uk/merchandise/p ... ctionID=49
I then installed a larger wheel which made it much smoother and gave a little longer travel. http://www.dellorto.co.uk/merchandise/p ... ctionID=49
Also had to adjust the stop under the pedal.
Ah I see - that's very helpful, thank you. That's the part I was trying to explain earlier, I think I'll email the supplier (Webcon) to find out if they can recommend a replacement / improved throttle wheel for my unit....
Re the pedal stop.... did you lower/shorten it then?
E21noob
My E21(s): SOLD
Post by E21noob »
You are welcome :)
First I removed it, but in the end I actually had lengthen it sligthly. I just user some threaded M8 (or M10?) steel rod.
When I said longer travel, I was comparing to the universal kit which had very short travel.
davidvincent
I see.
When I bought the Weber carb kit it wasn't supplied with a new accelerator wheel, I had to utilise the original bmw one.
