BMW E21 320/6 BAUR 1979 MODEL BEFORE FAcelift
phillbriggs
Post by phillbriggs »
well its not too bad, strip out under dash coverings, remove instrument cluster, remove all wires from back of dashbaord, disconnect all wires from switches etc. then there are about 4 or 5 small brackets that brace the dashboard to crossmember behind the dash, then there is one 8mm nut at each end of the dash underneath, they are hard to spot. then there are 2 clips on the back of the dash where it meets the screen, you need to just pull the dashboard up and they unclip. then a bit of riggling and its out. i would say starting from scratch withan interior in the car about 2 to 3 hours. i did mine in 3/4 of an hour but all then under side of the dash and the interior and windscreen were out so it was simple. p.s you dont need to reomve the interior and screen.
phillbriggs
latest pics from last few days, shell striped down to bare rolling shell for now untill i get it on a frame etc, engine trans out. now the big decision whether to go ahead and restore or not.
hobo
Post by hobo »
So what happened then?? :lol:
72' Alfa Romeo Spider
78' E21 Baur Cab
phillbriggs
thats the problem nothing, i had to push it back into storage as i ran oput of space in the main workshop, however, ideally i need to get it put onto a frame now and then get it sandblasted
--ALPINA--
Post by --ALPINA-- »
phillbriggs wrote:thats the problem nothing,
LOOOOL :D :D :D :D
Good one!!!
jimi
Performa
Post by Performa »
Like many said: You make my rust problems look like nothing. :) good job
