The Desert Rat's New Life. . .
tha_lick
Post by tha_lick »
yup 8)
the little knob thing inside the cluster is the adjustment for the shift light. . . iv not actually seen it light up yet but im sure iv set it to around 6k. . . ALSO. . . the illumination light dims with the rest of the interior via the light switch :D
thanks
drjim
Post by drjim »
The M10 rev limiter kicks in at 6k - I've tried it on trackdays! Set the shift light a bit lower, wouldn't want to overrev it too often.
1982 Saphirblau Baur 325i
Cars all gone!
tha_lick
Post by tha_lick »
ah ok fair enough. . . i was going to ask the question on m10 rev limit too. . . would adjusting the govenor be a good idea to try and rev it a bit more? or should they not be revved more than 6?
drjim
Post by drjim »
You can rev them higher if you want, they just go pop quicker, or at the very least snap rocker arms. Good post on M10 performance here...
http://www.ten-tenths.com/forum/showthr ... hlight=m10
I'd leave the limiter at 6 and try not to hit it too often - remember these engines are 25 years old and probably on original parts still.
I am considering a medium rebuild on my track car engine so I might rev that a bit more.
Cars all gone!
tha_lick
Post by tha_lick »
i cant believe how slow my 316 is. . . what is involved in fitting an e30 318is lump? could i use an m10 gearbox?
drjim
Post by drjim »
They aren't that slow - mine keeps up with faster machinery at track days - it's how you use it that counts.
M42 swap - talk to thetomc he has an ex 316 with one in it.
Cars all gone!
rob0r
Post by rob0r »
Tomc has fitted an M42, and I had one nearly in as well before I smashed the engine. Custom engine mounts are probably the hardest part of the swap, as well as an exhaust system. The manifold fits around the steering link, but you will need to adapt the old system to bridge it to the manifold and I've heard you will want a better exhaust than the M10 system anyway. M10 gearboxes won't fit, but M20s will bolt up except it will be rotated slightly if the engine sits properly level as the bolt pattern is rotated. You can use the M42 gearbox and an E30 prop fits perfectly and everything will be level, but you will lose the speedo. But then again my M50 shares the M42 gearbox bolt pattern and I've fitted an M20 box and bolted it up to the standard gearbox mounts and it's not that far out.
I started this conversion, and would be driving my car now had I not smashed my engine dropping it off an engine crane. I stopped and got an M50 6 cylinder instead, which is much harder to fit! If you look at my build thread in owners gallery, the early pages were dedicated to my M42 swap.
tha_lick
Post by tha_lick »
damn. . . i cant help but think there something very very wrong with my engine. its weird because the engine runs smooth, idles at 800rpm when warm, starts up on the button, 79k on the clock, no knocks or funny noises and the tappets are quiet as little mice. but it doesnt want to rev in the higher regions for some reason. maybe a proper carb should for out my troubles?
drjim
Post by drjim »
You may just need a proper tune up - new plugs leads dizzy cap and rotor arm made a noticeable difference to my car just before I got the new weber fitted. Electics might explain a hesitancy to rev past midrange. Equally your fuel filter could be clogged up and affecting flow, or your fuel pump may be struggling to supply enough juice.
I advise a tune up at a reputable garage so you can take it back if you aren't happy. Alternatively do what I did and buy all the bits, fit them yourself, then take it to a rolling road for the final setup (overkill but fun!).
See here...
http://www.bmwe21.net/forum/viewtopic.p ... yno+graphs
Cars all gone!
rob0r
Post by rob0r »
I still thought my 316 when it was standard was definitely quick enough, maybe something is wrong. Then again it is auto isn't it?
Sounds like it could be the distributor - siezed weights and base plate means the timing can't allow for the change in engine speed. Soak the internals in WD40 and move the plate to and fro to make sure all is as it should be.
drjim
Post by drjim »
I've got a spare dizzy if yours is beyond salvation.
Cars all gone!
tha_lick
Post by tha_lick »
cheers fellers for all the advise. i think ill go out and spend some money on good old mechanics and service equipement. im handy with a spanner so im 100% sure i can get the parts fitted. i think for tuning ill hand it over to the greesers. i cant imagine the distributers ever been changed and on opening the oil cap it i noticed it needs an oil change because the oil seems very thick. also i need to raise it, so new springs are on the list. . . anyone got any standard 316 springs going?
P.s. Wizor, im still going to need the manual conversion bits, im sorry its taken me so long. i picked myself a nice 323i for cheap so have been busy looking for a place i can store it for free as it hasnt got road tax. sorry and thanks
M15KYY
Post by M15KYY »
when i had the car mate i was going to strip and clean the carb out as it was caked in the proverbial but never got round to it, i know what you mean about it being slow, but i had a look at the dizzy and it seemed fine when i had it, as the guys were sayin maybe it needs a tune up, when i got it the car had been sat for at least 3 years so that probably hasnt done it any favours, i should imagine a manual box would make quite a difference?
E21 316 M60
rob0r
Post by rob0r »
No rush mate,
Rob
