coolant loss
Giorgio
Post by Giorgio »
It is one with 2 cables but it is not for the temperature instrument cluster .Upster the exhaust manifold had 2 sensors:one is the blue(for the ecu) and one gray(for the temperature instrument cluster in the panel).
Giorgio,
Found this: the ICV is controlled through the DME using the main relay. Most likely the data from the (blue) coolant temp sensor is the input used for its control. If the car runs, de main relay is ok... the coolant temp sensor is still under suspicion I think.
For measurements:
2 pin connector:
Ignition off : pin 1 and 2 at the ICV 6-10 ohms
Ignition on : pin 2 of harness connector 12V
Giorgos
Post by Giorgos »
Thanks Jeroen i will try it today.But i want to know also the second sensor of the thermostat what is for.ALso if you can told me the correct code of sensor and the manufacter because here the bmw dealer give me the same sensor of bmw 316 m40.So i dont trust the bmw dealer and i order it in another spare part shop
ItalianM3
Post by ItalianM3 »
Part no for the Temp guage (blue) is
B13.62.1.709.966
ItalianM3
Post by ItalianM3 »
Blue should be for the DME and brown should be for the Dash temp
Hmmm a true word.... I stand corrected again... I think I'll stop here! But no... I'll see if I can find out what that other connector on the thermostat housing is for...
Giorgio
Post by Giorgio »
Jeroen you helped me very very much and thank you realy for this help.I would sold my car before 8 months because of this reason.I have been in several bmw service to solve my problem but they take only money.I love this car very much and i dont want to sold it.What i find?In service socket the 11 and 19 with 1 and 3 of idle valve all the same.I have the wiring from the engine plug from m3 but i dont have from service socket and also the dme plug.I have one cd of bmw but it dont have the service socket and dme plug
