problemchild75
- e21-Mark
- E21 Master
Re: Mark's M52/2.8 + nitrous
Paint arrived.
The same, but different.
fire orange is an awesome colour tbh... esp in the sunshine
- Eddie.
- My E21(s): [O==[][]==O]
I'll look forward to how that comes out.
It certainly suits the E92.
- e21-Mark
- E21 Master
Really looking forward to seeing it painted too.
I owe a huge thank-you to Cat Camshafts. We are using there camshafts as opposed to the US M3 cams. If all goes to plan we should still see 240+ bhp without gas. We are going to do before and after dyno runs to see exactly what they give from a stock engine. The only mods will be bolt on and easily done by anyone else running an M52.
are they the same duration / what spec are they
problemchild75
If your going to the trouble of cams and the engine is not in why not change the rods and stroke it. One of my pals has 280 bhp out of an m52 with off the shelf BMW second hand parts, re map and BBTB
- e21-Mark
- E21 Master
Have you been going through my diary?!
harleytrike
What parts has he used problemchild
- e21-Mark
- E21 Master
There are 3 ways to stroke an M52 I think Matt. You can go as far as 3.2 but I guess it depends how much you want to spend?
http://www.Bummerfest.com/forums/archiv ... 11842.html
By the time you add up the rebuild after stroking the capacity up you well into m3 engine territory.
Unless your good at engine rebuilds enough to DIY it.
- e21-Mark
- E21 Master
I think it depends on the method you use and how cheaply you source the parts. I just missed a 330 bottom end last week that sold for £100.
The other factor is engine maintenance and the expense of something going wrong. M52's are terrific engines and they're cheap!
I'll stroke my engine if it turns up as a cheap option. If not, I'll be happy to stick with the 2.8, cams & inlet swap.
problemchild75
Crank and rods are main things. M50 rods and s50 crank is one way but m54 parts are interchangeable I beleive
problemchild75
Do it mark natural aspiration sounds much better.
. Harley get Nas to build it for you he's not got much on at the moment lol.
- e21-Mark
- E21 Master
This would be nice but not at £2100.
Even if it does say Alpina on it.
http://www.ebay.co.uk/itm/GENUINE-BMW-A ... 43b9abbb1a
