Pandemoniums 316 restore
pandemonium001
My E21(s): E12 535i T (ish)
Re: Pandemoniums 316 restore
Post by pandemonium001 »
The Wife says, "stay classic and no metallics!!" :loll
saw a bmw mini in the car park at work and its nice.
BMW mini pepper white,
Then i found this:
http://www.autoevolution.com/bmw-blog/m ... 58689.html
verde
My E21(s): 1983 manual 316 coupe
Post by verde »
This car is going to be absolutely wild!!!
IOd really love to get some shots of it up on our site
pandemonium001
Got some more done tonight with the help of a friend
In progress
more or less welded up just need to trim off the back side
more rust repairs
moved onto the front subframe
To this
Back end all finger tight just need to buy a 36mm socket for the hub nuts
second diff mount trimmed back ready for blasting
:banana :banana :banana
What do you use to cut small bits out?
Loving this thread.
:thumbsup
pandemonium001
nas80 wrote:What do you use to cut small bits out?
I use a combination of 4" grinder with 1mm cut discs, 80-120 flap discs, std grind discs, and a high speed air powered grinder with tungsten carbide bullnose tips for the difficult to get too bits.
e21-Mark wrote:Loving this thread.
:thumbsup
Thanks Mark
Thanks mate. I got some carbides somewhere forgot about them!
pandemonium001
Managed to get the rear castle nuts off tonight, bloody tight, needed a 6foot box section and a large 1 7/16" spanner.
just to do the drive shaft bolts and its all loose ready for cleanup.
got some of the front stuff blasted today, just the bush's to push out front bar to blast then paint.
looking at getting the rear ARB and camber castor parts soon.
measured the front ARB I have, its 22mm is this the 323 one?? looking at the 13.5mm rear ARB or should i go for the 14.5mm?
pandemonium001
A friend had these adapters made up for his 328i sport LSD build up, The splines locate fine just a bit long but do the job.
pre-load/slip/breakaway torque what ever you want to call it measured at 48Nm so happy with that, and back lash was around 0.004" so just goin to paint, fresh oil and bung it in for now.
Pushed out some of the bushes cleaned then the first coat of 2K epoxy primer made today, this is the good stuff with lead in it. Just one coat then baked at 60C for 1Hr.
A friend did the honours with the paint as I was busy getting it all ready.
can always adapt and re-paint the front subframe if changes are need for the engine.
will paint another few coats then laquer to get a good shine.
So nice to get rid of all the rusty stuff! :thumbsup
pandemonium001
Jeroen wrote:So nice to get rid of all the rusty stuff! :thumbsup
I had to for my own sanity :loll , really needed some bits I could see a drastic change keep the motivation going.
Started looking for more bits now, got my basket full at Strong flex ready to order when the budget allows. Keeping an eye out on Fleabay for a bargains as well, coilovers an the likes.
pandemonium001
Started putting the 2nd diff mount on
Just positioned it symetrical to the other side of the diff, think it worked out to around 26cm center to center, but time will tell if thats right.
trimmed off the extra metal
burned out the mounting rubbers
ground down the welds the other side then started whacking out some low areas with the dolly and hammer
punched some holes
test fit
screwed into place to allow for adjustment
Top of back panel tacked in place and boot lid tried for alignment
looks not far off
More screws, the panel was a bit deformed trying to get the old boot floor out so took a bit of clamping & hammering to get it straight and tight to the new panel
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
e_surprised what did you put under the car?
Always better to have a pair of hangers. :lol:
pandemonium001
Mihajlo wrote:Image
Nothing, the shell roll's up nicely on to the sill, nothing else touches the floor. all is fine.
