2.5 320/6 Racer -Oldman - So Ca USA
Old Man
My E21(s): '80US320iS '82US320i '79Euro320/6 BEAST
Re: 2.5 320/6 Racer -Oldman - So Ca USA
Post by Old Man »
Up-date on our track car build, work done June 21 & 22, 2014.
• We finished the engine assembled once off the engine stand with the flywheel, clutch, starter and tranny bolted up to it. We then installed the assembly into the car along with the shifter, headers, alternator, and drive shaft.
:boogie
• Doubled checked all the suspension hardware for torque and then finished running the front brake lines. Then bleed the brakes and cleaned up the mess.
HOPEFULLY SOON WE ILL BE :driving
:banana :cheers :shake
Not the fastest - but always fun to drive.
Clean work sir, and the cage, awesome. Nice progress! But, I was wondering if the front needs an additional cross bar, what are the thoughts on that?
Nice build indeed.
Old Man
Post by Old Man »
Jeroen wrote:Clean work sir, and the cage, awesome. Nice progress! But, I was wondering if the front needs an additional cross bar, what are the thoughts on that?
Thanks Jeroen and Peter.
There will be another front cross bar - in the second picture and others you can see the short flat tubes with gold bolt heads in them on the front down tubes. These are where the cross bar will go, but I need to finish the install of the motor and all the rest of the stuff like the radiator and hoses first. Then I can make it so it clears everything, it will be out of 1.5" OD tubing just like all the rest of the cage.
Clear! This is going to be fun to drive!
Old Man
Post by Old Man »
Jeroen wrote:Clear! This is going to be fun to drive!
Well if you ever fly over you have a place to stay and car to drive.
:P wondering what the weight distribution (F/R) will be when finished!
Any updates?
Old Man
Post by Old Man »
Jeroen wrote:Any updates?
Hi Jeroen I have been working on getting the dash in - but means I am making sure everything is done that is easier done with it out. Mostly looking and assembling in am mind at the moment.
Made a brake light switch holder for the Wilwood brake paddle assembly.
Microang
My E21(s): 1981 BMW 320/6 E21 Manual Sunroof
Post by Microang »
You're still using the 885 head in the engine aren't you? Which gaskets did you use on the larger intake ports?
Love this build, I've been following it on bimmer forms for a while now...
Old Man
Post by Old Man »
Microang wrote:You're still using the 885 head in the engine aren't you? Which gaskets did you use on the larger intake ports?
I need to look at the number on the head it is the E30 iS head - the used the stock gaskets and port matched the head to them. Intake gaskets for the head are way bigger then the ports in the intake manifold. Now sure how it is going to work not the best mating of intake to head :(.
Microang
Post by Microang »
Should be an 885 head then, yeah the ports are almost squares, I'm doing the same sort of setup on mine as I refuse to use fuel injection although mine will mainly be a road car. 4 barrels are the way for combining power and economy, can't wait to see how yours goes.
A good 4 barrel is as close to a muscle car as most can get in the UK, though here cornering is essential.
Old Man
Post by Old Man »
We did some more reassembly on the car this past weekend and as well as a little the weekend before.
We worked on installing the dash, wiring, gauges, windshield and external engine components. As for the open wiring goes, we plan on putting in some wiring loom once we get the motor running and everything working.
Gauges are the same configuration that we had in the car and the three lights above and to the right of each gauge are idiot lights for danger zones. Have to install the dial for the brake bias and figure out where to put the volt meter gauge.
Old Man
Post by Old Man »
Today I took the car for a ride.
To a friends place
Then strapped it down for some flogging
She gave me these results for my efforts.
Needs a little work on the engine but I am happy with the numbers! :) :banana
Note the two runs that were 164 hp were done with the secondaries disconnected so it was running on a 195 CFM two barrel carb!
Pulls were done in fourth gear from 3,000 rpm to 7,500 rpm.
Was already wondering what was going on there, but there's life! And not a bad result at all! Also matches your hopes, or expectations?
