Pandemoniums 316 restore
pandemonium001
My E21(s): E12 535i T (ish)
Re: Pandemoniums 316 restore
Post by pandemonium001 »
pandemonium001
pandemonium001 wrote:Linky to camber/toe guide:
http://www.e30m3project.com/e30m3perfor ... /index.htm
p.s the rest of Gustaves website on tech articles is pretty detailed and interesting.
pandemonium001
dimensions of rear camber plates:
pandemonium001
been doing a bit but not as much as i would have liked over the last 3 months, the summer increased the house and family duties.
rear arm blasted and bush removed
you can see the spacer tube
use these to remove
hammer through the housing to the other side alternate 180 degrees and walk the bearing out, it isnt that tight, dozen taps does it
both shims under the outer bearings measured equal sizes, I think these are set at the factory to allow for tooling and jig tolerances when machining the bores on the hub, the bearings should always be the same size when replaced, so you should never have to change them, just done get them mixed up with different hub assy's.
cleaned up these bits
need to remove the screw then paint
dont know if its worth painting or get a new one
got the camber plates machined
perfect fit
you get a total of 7mm lateral adjustment by turning to bolt 180degrees
some painted stuff
Full car kit, still waiting on my front rear bolt kits
This tank need replacing but thats on another thread
purchased a carbon propshaft
carbon one weights in at 5kg
e21 model weight 7.8
so if i do modify and splice them i might save a kilo
Have purchased som body shop stuff,
6 tubes upol gravitex
12 tubes u-pol tiger seal
various strip clean flap discs, another 25kgcrushed glass for the blaster spare nozzles, just need to order the epoxy primer now.
Got one of those camber plates spare? Need just one to replace one I bent (don't ask!)
I notice the end of the carbon shaft is completely different to the flange on the bmw boxes. How you going to mate them and what about balancing it?
Otherwise it's about time you updated us.
pandemonium001
I will see if the polished gearbox end on the composite shaft can be machined down to suit the coupling at the center bearing area, if its splined will have to do it on a mill or shaping machine. then just move the center bearing mount point.
the diff end just needs a 1mm spigot ring made, and slightly elongate the holes inward.
Part off the short shaft to length on a lathe then weld back together and x-ray.
Will try and get one more made up, I have not forgot.
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
if you'll be making the camber plates for nas80, could you make 1 set for me too? I'm willing to pay the asking price with shipping, no problem. Paypal or transfer...
pandemonium001
I dont know if i can get any more, I already asked about a batch being made. They where machined at work and its a bit dodgy for my collegues to make things for people outside work. I dont expect them to do it for free but they cant be seen using company time for profit.
I will however look locally to see how much i can get them made for and do a group buy, i cant see them costing much.
fraser
My E21(s): WANTED E21!
Post by fraser »
Just read all 16 pages, awesome stuff cant wait to see more
pandemonium001
After a Buisy few months, I finally managed some time on the E21 tonight.
altered the C of G on the spit by 2" now rotates a lot easier and made a link bar for the bottom to keep it more stable.
Painted the diff
Camber and toe plates for the rear subframe.
Re assembled the rear hubs
I will post "how I replaced rear bearings" in the technical section.
new cv boots on order then i can finish the driveshafts and complete the subframe assemblies and store away.
:thumbsup
pandemonium001
Also got these front Intrax coilovers for a good price, need to modify the front hub to the clamp style and set my ride height, they are about 4 inches shorter then the stock unit.
think the springs are around 250lb/inch plus the helpers.
Light as a feather, alloy housings, inverted shock so help unsprung weight.
caster and camber plates
polov8
Post by polov8 »
Good grief those are beautiful! Will be interested to see how the clamp conversion goes. Great work!
Andy
Lovely. Wish I had fabrication skills.
Expensive set I'm sure! Looks fab!
