BMW E21 327i (second racetrack video)
croma_man
My E21(s): '83 EU 327i
Re: BMW E21 327i (Looniticz INC final stroker pics)
Post by croma_man »
dreams can come true, today I got unpresidented access to the biggest Slovenian international airport for 20 minutes, run&gun photosession. Many other pics following...
That is a dream come true indeed!
croma_man
Post by croma_man »
Nice pictures!
Nice location for some pics, and turned out good, too!
croma_man
Post by croma_man »
thanks guys! If I could spend here a whole day it wouldn't be enough, so many ideas...
Jeffrey
Post by Jeffrey »
one of best. just your seats looks to new for me
SileNceR
Post by SileNceR »
croma_man wrote:Image
some stiffer springs for the rear, stroker kicks in very hard
How do the stiffer rear springs go? I have the same problem with my E21:
croma_man
Post by croma_man »
working all day every day...didn't have time to fit them yet :bag
Especially the rears aren't much work! :whistle
croma_man
Post by croma_man »
Jeroen wrote:Especially the rears aren't much work! :whistle
next excuse, it's always raining when I get to the workshop, can't drive in the rain :mrgreen: :mrgreen: :mrgreen:
Well let me return then, you don't need a workshop for the rears! Changed them on the street many times: loosen the three top nuts slightly on each side, then jack it up slightly under rear axle or diff. As soon as you see the tension is off the tops you're high enough already, wheels will still be touching the ground. Then you undo the lower bolt, remove the 3 top nuts and the entire package is off the car.
In my younger years changing both of them didn't take more than 15 mins!
SileNceR
Post by SileNceR »
Sounds almost too easy! Pretty well the same on an R33 skyline (and probably other IRS nissans)
Microang
My E21(s): 1981 BMW 320/6 E21 Manual Sunroof
Post by Microang »
I must say this has to be my favourite build on here, such attention to detail!
Is the steering wheel from a e24 and did it require modification to fit?
Also you say you're using an M20B20 block? What is your engine exactly?
Look forward to seeing more... :driving
croma_man
Post by croma_man »
Microang wrote:I must say this has to be my favourite build on here, such attention to detail!
thanks mate !
Steering wheel is from a E30 (with some force, it fitted)
This is a genuine ETA M20B27 with high compression block, crank and pistons, and M20B25 head with a lot of modifications.
