Problemchild75s 1983 safari m52
Re: Problemchild75s 1983 safari m52
really nice build , readed the 19 pages lol.. keep it going and people not serious are everywhere , it's strange that someone that sell an engine do that but well , somtimes happens! keep it going sir!
problemchild75
Thanks. It's all sorted now LLLLLLLLLOOOOOOOOLLLL. they have blown the pirts out and spun the engine and say it will be fine. And sending it back to me. I flipped big time. These guys are f*** comedians. Needless to say after a few phone calls I got a refund and no doubt some poor soul will get that engine sent to them.
On a plus note welder turned up on time worked quickly, did a awesome job , tided up and went. I will post pics tomorrow. If only all tradesmen worked that way.
- e21-Mark
- E21 Master
If they said it's fine, it must be true.
I told you my welder dude was awesome. Glad something went right.
problemchild75
- croma_man
- My E21(s): '83 EU 327i
I see you are using the tilter lift...how is it?
problemchild75
If you don't like lying under the car on your back the tilter is awesome. I wouldn't be without it.
- e21-Mark
- E21 Master
problemchild75
The other diff mount will be removed. I will just need a single bush bolting downwards from the boot floor.
- mcjjordan
- My E21(s): Uk 1980 316 m52
hows the new diff coming on?
did you have to alter the drive shafts?
I can answer as I run the same setup -
he copied me and fitted an e12 diff. the beauty of this diff is that you can use your existing drive shafts and prop.
- Eddie.
- My E21(s): [O==[][]==O]
Can you not with an E21 LSD?....
if your name is Problemchild then no not really as its not strong enough. hence the e12.
- Eddie.
Ah so the issue is the E21 LSD can't take the power/torque from the M52?
