Brake linkage delete
Re: Brake linkage delete
its near enough the same - i cant remember where i got it but i have an excel spreadsheet version - Beauty is that it has all the formulas, you just enter the data and that website does the same thing.
I sorta posted the above article to just to confuse Mark :)
A bit more progress today, in as much as hopefully an aftermarket manufacturer is possibly putting a kit together using my car as a test mule. They'll be aiming to keep their callipers within a 15'' rim too.
harleytrike
Post by harleytrike »
sounds good
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
Nice, I found a website in the states that sells a wilwood kit
http://www.massivebrakes.com/brake-syst ... _front_300
and a very long thread on E30 booster delete.
http://www.e30tech.com/forum/showthread ... 29&page=34
Jason_323i
Post by Jason_323i »
Lee is actually in Canada and a few of here have used his Massive brake kit, he allo make a booster delete for the e30 which remounts the stock master clyinder and change the ratio to 6:1, my calcs show a 6:1 should stop an e21 okay without a booster.
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Went with the e12 master cylinder as the outlets are on the opposite side to the e21 m/cyl. Started cleaning up the mounts & callipers ready for repaint although hopefully there will be another alternative.
so your keeping the stock servo?
I hope not. If we do though, it'll be without all the linkage.
pandemonium001
What size is the E12 master?
24mm
