DrGonzoPOW's 1981 320/6 - 325i -Race'in Up-
- e21-Mark
- E21 Master
Re: DrGonzoPOW's 1981 320/6 - M20B25 conversion COMPLETE :)
Brilliant! Congrats on all your hard work paying off. You must be loving having the e21 back on top form again?!
- DrGonzoPOW
Really happy mate. Big thanks again to John for all the work he did for me and all the advice i got from everyone. Still got a few jobs to finish up on but its back on the road for another year!
Wakefield Hellfire
woooo hoooo, yeah baby!
is it fast then?
you coming up to the nas/mark meet?
is it fast then?
- DrGonzoPOW
Yeah, its pretty dam fast to me. Wheels spin in 1st, 2nd and 3rd from standing start. When you meeting up ??
Wakefield Hellfire
satdee i think, tho the time is up in the air at the minute.
http://www.bmwe21.net/forum/viewtopic.p ... 8&start=30
- DrGonzoPOW
Ill keep and eye on it mate.
Absolutely loving the car! Its well fun to drive, forgot how good the steering is on it too. Got to behave now though, been told me clutch needs bedding in
Wakefield Hellfire
i gave the flywheel a good rough up with some sandpaper to stop the new clutch glazing on one side as it beds in.DrGonzoPOW wrote:Got to behave now though, been told me clutch needs bedding in
but yeah, id take it easy on it for a few miles. not so much nailing it, more holding it on hills/junctions slipping it etc.... which you shouldnt really be doing to excess anyway.
- DrGonzoPOW
Nar, i usually knock it out of gear at junctions anyways. Ill take it easy for a bit though. I very impressed with it mate. Just need to sort the tatty bits out now.
Wakefield Hellfire
- DrGonzoPOW
Little bit of a problem with the car when returning to idle. If you take your foot off the gas, or drop the clutch, the rev's drop really low. Almost to the point of cutting out. Its only a little niggle i guess, it still runs sweet. What could be causing this though ?? Idle air valve, Air flow meter ??? Any idea's anyones ?? Ta
Wakefield Hellfire
cobbler2u
- My E21(s): 323i baur
323i special
328 sport
might be dirt in throlle body
Vacuum leak? Does it hunt or miss a little on idle ??
- DrGonzoPOW
Seems to idle pretty solid to me
Wakefield Hellfire
put your AFM the right way up and see if it still does it - if theres a some sort of flapper in there it might be having a moan about being upside down?
- DrGonzoPOW
possibly ay, will have a poke around on the weekend
Thought id try an arty picture of the old girl
Wakefield Hellfire
maybe give the idle valve a clean out.
also have a close listen to the throttle body (without it running). the throttle position switch under the thottle body, should give a click just as you move the throttle flap off its bottom stop and again when it closes.
tho i dont think its this cus if it wasnt working it'd be hunting up and down all the time while it was idling.
