Can anyone tell me what the resistance for the E21 tank sensor is at full/empty?
My google-fu only found this (
http://forums.bimmerforums.com/forum/ar ... 92201.html) which states 74ohm empty and 3ohm full.
My fuel cell purportedly (I say this because the -AN fittings were different to what the sale stated!) came with a 90ohm "GM" spec sender - i.e. 90ohm when empty and 0ohm when full.
If all E21's do indeed expect 74ohm as "empty" then I will adjust this sender with a ~400ohm resistor in parallel with the sender (for a total resistance of 73.5ohm or as I like to call it "close enough")
Also, I assume the fuel guage is sent +12v and the other lead flies out to the fuel sender which is then grounded on the other side. Is this correct? If nobody answers that part I'll just assume so
