Wheel advice please
Re: Wheel advice please
not without looking at them. 90% of 15" wheels that are fitted to e21 have too high an offset - this means that if the ones on it are more than et13 then you will spacers.
- cookster
- My E21(s): 1983 323i Auto Kashmir
Hello
Does anyone know, or have experience of whether I can replace my standard 13" alloys with:
15" x 7J rims (offset is +20) fitted with 195/45/15 tyres?
I can't use spacers as they're illegal here in Aussie.
I don't want to run the risk of knackering my wheel arches or suspension.
Cheers
Mark
Cheers
Mark
e21 323i Kashmir Gold build date 1982 - original spec all round - Australian delivered/registered in 1983
Your answer is one post above yours. Let's say it is 99% sure the offset is too much. You can test fit of course.
Also see the FAQ section http://www.bmwe21.net/forum/viewtopic.php?f=38&t=18256
- cookster
Thanks Jeroen
I wasn't sure if the 7J was also an influencing factor.
I'll hold out and search for some with et13.
Cheers
Mark
Cheers
Mark
Yup, rim width is and for 7J that should be abt 13mm indeed.
