That's coolSierpien wrote:Nice work!
Also never seen that Pioneer central console before! very rare!.
My uncle in his E21 has something similar but made with aluminum, i think the made it based on pictures of your console.
My BMW 323i 1982
- Bobben
- My E21(s): '82 323i
Re: My BMW 323i 1982
- Bobben
They are not going anywhereuwbuurman wrote:No pioneers from the factory, but why not use them anyway? They are period correct.
Any info of any stereo stuff was mounted at the factory or if it was only available as an option (not necessarily Pioneer) ?
- Bobben
Well, first time this has happened to me, a broken spark plug!
On Saturday 23:rd I was going to get some fuel, since I was down on the "R" on the gauge, but no low fuel warning light (not sure if it's working, bulb is okay though) and just after a short while it started to run rough as if one or two cylinders didn't fire, so I thought it was the fuel and decided to continue on to see if I indeed was out of fuel, but it kept running and a minute or two later it started to run normal again so I continued to the gas station. Then when I had filled her up and went to drive home, immediately after starting, it was running bad, definitely missing a cylinder, so I had to creep home at about 30-40Km/h for about 5-6Kilometers hoping that it would clear up, but this time it didn't.
The first thing I did (when I got home) was to remove the spark plugs to see if maybe there was a cylinder that didn't get any fuel, but they were all slightly wet. So started to inspect the spark plugs closer and found this from cylinder nr. 2:
As you can see, a bit of the ceramics around the centre electrode is gone.
No wonder it was running bad! Luckily the little ceramic bit didn't fall out as can be seen in picture nr. 2.
It's stuck under one of the side electrodes.
Don't know what kind of damage that could have done if it's gotten loose...
Running the same 4 electrode plugs in my old Benz, that has gone much longer (more than 30 000km, since last change), with no issues, so I don't know what caused this.
Maybe fine crack from factory or dropped somewhere along the way to the auto parts store, who knows.
This time no more plugs with 4 electrodes, just regular BP5ES and now it runs smoother than it has in years, but not sure if it's the new plugs or the two stroke oil I added to the fuel shortly before the plug failure, or a combo of new plugs and oil...
As for the additional instruments, there is a topic in the Top Tech Topics section:
http://www.bmwe21.nl/forum/viewtopic.php?f=61&t=19387
As for car stereo, the only things you could opt for from the factory, as far as I know, was a radio preparation kit (speakers, antenna and wiring) and a choice of BMW Bavaria and Becker radios like the pic below, taken from a 1981 factory brochure.
That broken spark plug... wow! Not something you see every day indeed but yes, I agree that it is most likely to be a production issue or the spark plug was dropped at some point. They look like Bosch Super 4's, correct? As far as I've experienced myself these do work best in M20 engines, even used them in my E30 race car back in the day, and I've never had a Bosch spark plug fail.
- Bobben
Thanks Jeroen, for the link and stereo info
Yes, it was the Bosch Super 4's. Did think about going with them again, but the store didn't have them and they are quite expensive, so I went for the NGK BP5ES.
They should hopefully last me a life time, since I don't drive that much with it, only done slightly over 25 000km since I bought it in 1999
I do nearly that amount in one summer ;D
But maybe there is a better way to find to mount your fan. There are many that tell about those tie wraps and clamps being pulled through the radiator...
- Bobben
I have thought about it but it has worked ok with the first fan I had and ok with the second fan in the old radiator and now also in the new radiator.
The current mounting that I'm using, is made specifically for mounting a cooling fan to the radiator.
Looks exactly like these: https://www.americanvolt.com/products/s ... traps-pads
I don't think there is a risk of them pulling them self through the radiator, at least not a new one, an old corroded one, then I guess there's a chance.
But I'm always up for improving things, so you never know
Ah, there you say something, aluminium radiators are more sensitive of course.
- Bobben
A little more information regarding the stereo, managed to take one front speaker out and have a look, this is what I found:
The fronts are TS-461 with Pioneer speaker grilles (no part number on that unfortunately).
Googling TS-461 gives pretty much zero info, there are some TS-P461 and TS-H461 but those are much newer and not the same.
I'm beginning to wonder if Förenade Bil (who was the main BMW dealer in Sweden in the 80's) had these Pioneer stuff as options only here in Sweden...
Since the TS-461 is mentioned here: https://www.garaget.org/?car=4814 and this is a BMW sold in Sweden and it also has almost the same rear speakers as in mine.
Also saw a BMW (I think it was an E28) in the scrap yard (close to where I live) some 10-15 years ago which had what looked to be TS-2080 in the rear.
Might have to contact Förenade Bil to see if they can shed any light on this, if there's anybody still there that remembers/knows that is...
