Eddie's E21 316
Eddie.
My E21(s): [O==[][]==O]
Re: Eddie's E21 316
Post by Eddie. »
Got the number plate mounted up too.
I was keen not to screw the number plate to the bumper, mainly because I don't want unsightly screws showing on the plate, and drilling the plate is very "permanent". So I made a plate that is mounted to the bumper as per the normal method, and then the number plate is mounted on that plate.
So, metal plate measured, cut and mounted. It's smaller than a number plate so cannot be seen:
Image[/url
This was then painted up to keep it clean and tidy:
[url=https://flic.kr/p/CpzmsG]Image
And then the number plate fitted:
Much cleaner and tidier than screwing it on IMO.
Re: Eddie's E21 316
:thumbsup attention to detail!
Re: Eddie's E21 316
looks sweet!
Eddie.
Re: Eddie's E21 316
Post by Eddie. »
So the time had come for a new throttle cable, the old one was a bit of a bodge and I really don't know how it lasted as long as it did.
Anyway, got all the parts I needed from Venhill:
Needed to make 2 new brackets in total, as I wanted a good amount of tension adjustment in the cable, first bracket being cut out, bent up and a thread putting in:
Next up I needed to modify the throttle arm, as it was fouling on the sound deadening I have fitted, so the pedal was struggling to return correctly. I didn't really want to cut up the sound deadening, so I made some basic changes to the arm itself:
This "kink" allows the arm to move freely. I've also included a hole for the clevis pin to attach to the arm.
All fitted up:
Third bracket made, which picks up on two points on the inlet manifold:
And finally some photos of the brackets painted, fitted and the cable all finished:
Re: Eddie's E21 316
Some nice detailed work... and functioning like it should again I hope?!
Re: Eddie's E21 316
Nice work indeed, but what's the advantage to an original one?
mcjjordan
My E21(s): Uk 1980 316 m52
Re: Eddie's E21 316
Post by mcjjordan »
Think i spotted this car today in droxford hampshire
l1mex
My E21(s): '83 EU 315
Re: Eddie's E21 316
Post by l1mex »
Nice! Do you have any pics of your subframes for opel recaros?
