E21 323i - ex315 from Croatia
- Mihajlo
- My E21(s): 1982 315swap323i
We puted Bilstein B6 in fi51 (323i) struts and vented ATE discs, ferodo brake pads, and earlier widened brake calipers
but everything was not bolt on.
wheel hubs from old 48 struts don't fit 51struts,
exhaust system is partly from e30 partly from supersprint for alfa romeo...
K-jet is behaving stupidly...
on idle and up to 3000rpm is just fine and then is cut off.
and we fitted front bbs and LSD
- Mihajlo
noebody knows... nothing is written on them and don't know which brand is. (but they are pretty stiff)austin25uk wrote:like the suspension, what rating springs are on it
they are compresed almost an inch when loaded on car. (hope it helps)
- Mihajlo
OK, it's done.
we have little problems with fuel pump and fuel gauge sensor and that would be it.
car is handling wery well and I'm very happy with fuel consumption.
3.45 final gear ratio is overkill!
- e21-Mark
- E21 Master
- Mihajlo
That is not possible because geometry of the wheels.austin25uk wrote:me thinks the back needs to go a bit lower
If rear end goes more down, toe get more positive anad castor more negative and that is very tricky in wet conditions...
Before swap I was driving those bravuris on lower rear end than now is for 2500-3000km and iner side of tyre is already outworn 3mm's more than outer side.
you need adjustable rear camber bushes and bolts
http://www.iapdirect.com/product.php?productid=42000
these are more local
although a man of your skill can probably make these easily
http://cgi.ebay.co.uk/BMW-E30-rear-camb ... 3001r12393
- Marquis Rex
- Newbee
It's very heart warming to see the love, attension and dedication you've put into this dear old E21. I also find it refreshing with schemes like Europes Scrappage scheme in Germany and in the UK colouring peoples opinions of old cars and promoting this dispoable car culture and 'rampant consumerist society we live in today.
Rear Wheel Drivers Do It Sideways...
1982 BMW 323i-2.7,schrick, forged pistons, Alpinas
1995 Porsche 993 Turbo
1970 Dodge Challenger 440 R/T
2003 Dodge Ram 1500 quad cab pick up
- Mihajlo
little update...and winter outfit
BBS MAHLE 5.5x13 ET13 with tyres Sava Eskimo 165/70/13 I used last season. They are stil soft and sticky! leaving black marks on every corner...
and today during wheel change, i noticed left rear shock is covered with black grease... probably the shock is leaking. but it's working good so far.
- Newbee
