Bent out of shape!!
cdavie2002
Bent out of shape!!
Post by cdavie2002 »
Not the car just a part.
Got a set of rear calipers shot blasted, the part that bolts onto trailing arm where the other caliper half slides up and down on has been bent out of shape! I will try and post a pic later today, but how can i bend it back? Is this metal cast? I tried heating it with a blowtorch, maybe i cant get it hot enough!
Thoughts
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
Re: Bent out of shape!!
how the hell did you bend that!
Just get another one from a breaker mate. Straightening it might cause it to crack or fail all together.
Jason_323i
Post by Jason_323i »
I can't believe thay bent it have they sent you back the right part
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
rob0r
Post by rob0r »
I should have a pair of E21 rear calipers you could use to get the bit you need. PM me if interested.
I wonder how they've done it as well!
cdavie2002
I dont know how they did it! I dismantled them and they were fine. its a small coatings shop, they dont do a lot of car bits, definately mine. Buggers
Chris
1975 3.0 csi
2003 E46
