the modding bug bites... time to turn up the 320i
Posted: Wed Nov 10, 2010 2:07 pm
Hi all
wow... I haven't posted for ages - I hope all is well with everyone. Having 2 kids really changes the amount of time I have for forums (and my car) these days
Anyway - about a year ago now, I bought my '88 320i auto, and have been happily cruising (slowly!! but very smoothly!!) around in it. I really like the smoothness of the 2.0L M20 vs. the larger capacities, although it is worse on fuel around the city than the 323i ever was, even when it was a 3 speed auto! Sure it's slow, but it's been an exceptional daily driver and the 4 doors make it very practical.
The only mods I have done to it so far are a conversion to a 3.7 medium case diff (geared down from the small case 4.10, which made it even slowwer!) and a set of the optional BBS basketweaves. This is all about to change, so I thought I'd ask for opinions.
I have managed to pick up a complete set of new urethane bushes cheaply with the works... it has adjustable strut tops, offset M3 front bushes, eccentric rear control arm bushes, sway bar bushings, subframe bushings, gearbox mounts, engine mounts etc.... and a set of new eibach springs. Basically a guy abandoned ship on his project car and was offloading un-required parts.
Just wondering what the best option might be for me with shocks. Bilstein Sports cost a bomb down here, and even with the high Aussie dollar at the moment will be a stretch for me. If they are truly are the be all and end all, then I could save up for a while and stretch
The other problem I have is I already have a new pair of rear Bilstein Tourings, so buying a pair of fronts is obviously a much cheaper option. Can the Tourings work with lowering springs - the Eibachs aren't super low, or crazily more stiff than stock? The car is unlikely to be going near a track ever, and will continue to be my daily driver. I had intended just to refurbish the stock suspension (hence the tourings purchase), but the eibachs were a bit too cheap to pass up.
Are there other options from Boge or somewhere else that might work well with the eibachs on a daily driver? (I think adjustable Konis are probably a bit overkill on a car that doesn't go near a track)
I am also going to convert my auto over to manual to speed things up a bit + hopefully build my 2.7L stroker up finally to speed things up a bit more! Suspension and brakes come first though.
Thanks in advance for your opinions
Sorry for the loooong first post back
Luke
Luke
