Chassis
Posted: Wed Dec 22, 2010 7:11 pm
The most known issue on the E21 chassis is rust! Not that strange considering yesteryears' steel quality and rust prevention, let alone the car's age!
Most common places (I hope we can get some pictures down here!)
-Top of front and rear shock towers
-Inner wheel arches & fenders front (check top and a-pillar)
-Inner wheel arches rear (check in trunk and remove rear seat to see all!)
-B-pillar around halfway
-Trunk (also remove spare wheel and check where the fuel fill pipe crosses the wheen arch)
-Around the front the windscreen, mostly bottom half
-Around the sunroof (if applicable)
-Inside the hood
-Front beams in the engine bay
-Bottom/floor (general)
Another common issue is the glovebox filling up with water after heavy rain. Either a worn windscreen seal or rust underneath it will be the cause. Be careful what you store in your glovebox!
Nice topic on removing the windows from your E21: http://www.bmwe21.net/forum/viewtopic.php?f=3&t=18614
-Inside the hood
