getting over the pits
Posted: Sun Apr 03, 2011 6:59 am
hi all,
my e21 has been yellow stickered because of the exhaust. its no problem to change it but my car also has bad rust, the springs are cut and there's a pod filter sticking out the front. te filter i can rectify without a problem and the same with the rust. the only thin gim not too sure about is that i have a rattle coming from the left hand side of the car. it goes away when i turn corners so i figure its probably a whell bearing. so i was wondering if anyone else has ever taken an e21 over the pits and if anyone knows what theyre most strict on when it comes to e21's. also if anyone has had this rattle before would you be able to let me know what the problem turned out to be so i can fix it. i only have 2 weeks or the car gets unliscenced. any help is great.
cheers
jordan
cheers
jordan
