Oil Service
Posted: Mon Apr 04, 2011 11:56 pm
by MRE21
Anyone know what grade oil I should use for my 320/6?
Cheers
Ally
Re: Oil Service
Posted: Mon May 02, 2011 6:23 pm
by cdavie2002
15/40 mineral, iirc
Re: Oil Service
Posted: Tue May 03, 2011 12:11 am
by E21meister
You can also use 10w/40 semi-synthetic (as I do on a B23 lump) depending on the age & mileage of the engine, this was Opie Oils advice to me. 5,000 miles on, it's proved a good decision. All a 'semi-synthetic' is, is a combination of as little as 5% (and no more than 30%) hydrocracked oil. However if your engine is high mileage and original, then a 15w or even 20w/40 will be a better better bet due to wear.
Re: Oil Service
Posted: Tue May 03, 2011 7:53 am
by petroscf
Ok, can I also ask the same question for my engine?
179000 km, genuine inside except for the weber carb and handmade air filterbox (no air filter actually)
At about 100000 it started burning some oil, and I had a valves and springs replacement.
Otherwise it's totally factory, nothing else.
So what oil type should I use?
Re: Oil Service
Posted: Tue May 03, 2011 10:40 am
by E21meister
E21meister wrote:However if your engine is high mileage and original, then a 15w or even 20w/40 will be a better better bet due to wear.
If your piston rings are original, I personally would go for a higher viscosity as above, as there is bound to be wear and therefore more chance of a thinner viscosity oil (like a 5w or 0w) pushing past the rings into the combustion chamber.
Of course, this is only my opinion and you should get the advice of someone more qualified, but going by all of the info I've had told to me over the years, that's what I'd do.
Re: Oil Service
Posted: Wed May 04, 2011 7:35 pm
by MRE21
Thanks guys I used 15w40 semi-synthetic as the mechanic told me that is what he used last time! Ally :launch
Re: Oil Service
Posted: Sun May 08, 2011 2:31 am
by murran
10w40 semi sythetic goes in mine. if theres no sign of it burning oil then id go with that. what went in these from new 20w50 mineral?
Re: Oil Service
Posted: Sun May 08, 2011 12:49 pm
by E21meister
murran wrote:10w40 semi sythetic goes in mine. if theres no sign of it burning oil then id go with that. what went in these from new 20w50 mineral?
That's what the Haynes manual says - 20w/50. I might ask the classic specialist at BMW Park Lane when I get the chance.
