BMW 315 -> M42 Turbo 240 hp
Posted: Tue Apr 05, 2011 3:13 pm
Hello,
wanted to share my project with you on this site because i am always reading and not posting
i fell in love with a stock bmw 315 1983
opalgrun metallic
15 inch mim wheels with 195 40 15
lowering springs
1500 carb engine
4 gear box
tacho with rpm! original?
i had a very nice e36 318is with turbo
8.5 :1 (compression with evo pistons)
but the engine broke down and i didnt want to spend more money om my cars so i stopped investing. i sold the e36 in parts, the only thing what was left was the broken engine with turbo. as i said i didnt wanted to invest any more money so i builded a new stock engine wich was also laying around in my garage.
stock engine compression 1:10 (max boost = 0,6 - 0,7 bar approximatetly more than 200 hp)
port and polished head
MLS gasket(used for the 4th time
ARP head bols
ARP conrod bolts
e30 oil pan
TD-05 turbo
440cc injectoren
forge intercooler
standalone management
the stock e21 1500 started to burn oil a lot and i had to give full throttle to go with the traffic with my 70 hp, so i decided to swap the engine, altough i didnt now how i would fit and i wanted to do the suspension and brakes first.
i am very busy with school and working but on a crazy evening i decided to pull the engine out in the mechanic shop i work in. i pushed the stopwatch and pulled the engine out in 90 minutes.
i fitted the m42 and is sits very good.
the next evening i welded the mounts and on a saturday i fitted a e36 318is drive axle and completed the cooling,wiring etc (i have done more bmw project so i can wrench on BMW blindfolded)
i pulled a VW transporter midmuffler out of the old iron bucket bought a steel exhaust pipe and welded the exhaust.
Because i wanted it to be finisched and driveable fast i didnt pay a lot of attention to detail so is still have to clean up the wiring and intercooling tubing etc, but hey it drives!
removed the bbs and front bumper to see how it looks, you can also see my intercooler
i am very busy, so i still need to dyno it. AFR is to rich at the moment.
thing to do very soon:
clean up wiring DONE
install tacho with working fuel meter DONE, km DONE and rpm meter!! i drove it around with my laptop so i could watch the coolant temp.
make a bracket for computer
fasten the battery and main cable with main switch DONE
replace connector for wideband lambda, right now it blocks the 5th gear! DONE
things to do for future:
install good stabi's
install adjustable shock absorbers with racing springs
roll cage
semislicks
brake upgrade
clean up outside with custom sheet metal
opalgrun metallic
lowering springs
1500 carb engine
4 gear box
ARP head bols
ARP conrod bolts
e30 oil pan
TD-05 turbo
440cc injectoren
forge intercooler
roll cage
semislicks
brake upgrade
