m20b25 issues
Posted: Wed Apr 06, 2011 1:38 pm
lads
i fell in with an e30 325i sport mtec 1 local car, lay up in a garage for over 10 years good history, good body, good suspension, good interior however i bought it understanding the engine was scrap it was ungodly smokey and the oil was everywhere it was dripping from the exhaust clamps and even in the air filter.
on further inspection looking at the dipstick the oil was full of petrol and obviously off a few cylinders.
i changed the oil and it is not "as" smokey
a compression test has yeilded good results on all cylinders. and a bore scope has shown nothing out of the ordinary.
it is getting spark to all the plugs however i do have a new distributor cap rotor arm and plugs to fit. a resistance test across the leads look good around 6 ohms each
a resitance test across the injectors read 16 ohms each i think that is ok. however when i touch my test lamp to the injector plugs it stays on on both terminals i was expecting a pulsing action.
this has led me to believe that something is telling the injectors to stay full on and the excess petrol is getting into the oil thinning it out and its going everywhere.
i am beginning to think that the brain (motronic 073) may be at fault but i am not a car mechanic and know that some of the guys on here are well clued in with these m20 engines
i think the car has been started and stopped alot that may be a contributing factor
anybody seen this before or any advice on where i should look next would be much appreciated
willy
willy
